CDR Ouput ClienMatterCode
Apr 26th, 2010
I have a output CDR File, in this appear this field of Forced Autorization Code
authCodeDescriptionauthorizationLevelclientMatterCode
VARCHAR(50)INTEGERVARCHAR(32)
Abigail Lozano20
Abigail Lozano20
Agustin  Lopez30
Alfredo Sanchez R60
Araceli Saules60
Araceli Saules60
Claudia Rosales20
Hector Galindo30
Then in the third Field not appear the code number that the client dial to get access to PSTN.
Any Idea to show the value in this field.
Ivan Mendoza
Robert Thomas Mon, 04/26/2010 - 15:02
  • Silver, 250 points or more
Hello Ivan,
FAC and CMC are different concepts. CMC will just record a value for accounting purposes and let the call go through while FAC will check for the autorization level. If you are using FAC and would like to know the actual code they press you should be looking at field authorizationCodeValue.
Pablo Ivan Mend... Mon, 04/26/2010 - 15:15
I'm Look at field and this but also this is in blank
VARCHAR(32)
I must to configure something to do that this authorization Code Value appear.????
Robert Thomas Mon, 04/26/2010 - 18:12
Ivan,
There's actually a service parameter in CallManager that determines if the value you input is recorded into the Flat file. It's called something like Display FAC in CDR. Make sure it's enabled in every CUCM server.
Cheers,
