Nexus 1000V, HP Flex-10 port speeds
Apr 26th, 2010
Afternoon,
We are currently deploying a new VMWare Environment utilising an HP C Class Blade Chassis, Virtual Connect 10GbE modules, BL680 blades with Flex10 NICs, Nexus 1000V virtual switch and Nexus 5010 switches.
i.e.
Nexus 5010 -> HP VC 10GbE -> Flex10 NIC -> Nexus 1000V Virtual Switch -> VMWare
In Virtual Connect the Flex 10 NICs are divided into two, with a 1000Mbps and 9000Mbps interface on each. These show correctly in VMWare.
We have configured a port profile for the Nexus1000V Uplink to the LAN as follows:
port-profile type ethernet Trunk-Profile
  vmware port-group
  switchport mode trunk
  switchport trunk allowed vlan 2-1200
  channel-group auto mode on sub-group cdp
  no shutdown
  system vlan 1094,1196
  state enabled
This comes up just fine, we can connect to VMs on Port Profiles created and everything looks OK. However doing a show int brief shows all interfaces and port channels up at 10Mbps. Initial testing on the VMs suggests the networking is running above gig speeds so this may just be a display bug but I cannot find any mention of this issue anywhere (HP, VMWare and Cisco sites along with copious googling).
My options for forcing the port speed are only 10,1000 and 10000. If I force to 1000 it drops then comes back up at 10. If I try and force 10000 I get an error: Configuration does not match the port capability.
Has anyone seen this before or know what could cause it?
This is what we get if we do a show int brief:
Port     VRF          Status IP Address                     Speed    MTU
mgmt0     --           up     10.153.94.21                   1000     1500
Ethernet      VLAN   Type Mode   Status  Reason                   Speed     Port
Interface        Ch #
Eth3/2        1      eth  trunk  up      none                         10(D) 1
Eth3/3        1      eth  trunk  up      none                         10(D) 1
Eth4/2        1      eth  trunk  up      none                         10(D) 2
Eth4/3        1      eth  trunk  up      none                         10(D) 2
Eth5/2        1      eth  trunk  up      none                         10(D) 3
Eth5/3        1      eth  trunk  up      none                         10(D) 3
Eth6/2        1      eth  trunk  up      none                         10(D) 4
Eth6/3        1      eth  trunk  up      none                         10(D) 4
Eth7/2        1      eth  trunk  up      none                         10(D) 5
Eth7/3        1      eth  trunk  up      none                         10(D) 5
Eth8/2        1      eth  trunk  up      none                         10(D) 6
Eth8/3        1      eth  trunk  up      none                         10(D) 6
Port-channel VLAN  Type Mode   Status  Reason                    Speed  Protocol
Interface
Po1          1     eth  trunk  up      none                        a-10(D)  none
Po2          1     eth  trunk  up      none                        a-10(D)  none
Po3          1     eth  trunk  up      none                        a-10(D)  none
Po4          1     eth  trunk  up      none                        a-10(D)  none
Po5          1     eth  trunk  up      none                        a-10(D)  none
Po6          1     eth  trunk  up      none                        a-10(D)  none
Interface     VLAN   Type Mode   Status  Reason                   MTU
Veth1         60     virt access up      none                     1500
Veth2         60     virt access up      none                     1500
Veth3         2      virt access up      none                     1500
ctrl0     --           up     --                            1000     1500
