how to find switchport downtime
after1111
Is there a way to find out how long a switchport has been down for? Is it possible to find out using CLI?
I've one command and you can also try that. I use this to find out how long the switch port was down using the key word mentioned in the show interface .
SW-***-226#sh int fa3/0/12
FastEthernet3/0/12 is down, line protocol is down (notconnect)
  Hardware is Fast Ethernet, address is 001d.464b.1e8e (bia 001d.464b.1e8e)
  MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
  Keepalive set (10 sec)
  Full-duplex, 100Mb/s, media type is 10/100BaseTX
  input flow-control is off, output flow-control is unsupported
  Last input 6w6d, output 00:01:16, output hang never  ---- This switch port was down for 1 minute and 16 sec
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
     251840614 packets input, 80100244231 bytes, 0 no buffer
     Received 373073 broadcasts (0 multicasts)
     54245 input errors, 54243 CRC, 0 frame, 0 overrun, 0 ignored
     0 watchdog, 154250 multicast, 0 pause input
     422495720 packets output, 245309822100 bytes, 0 underruns
     0 output errors, 0 collisions, 3 interface resets
SW-****-226#
But once the port comes up the output 00:01:16 will set to 00:00:01 depends upon switching frames/time
ThiyaguVG.
Leo Laohoo
Depends on the model of your appliance.  Otherwise, you'll have to use SNMP.
SW-****-226#
ThiyaguVG.
ah hah...never notice that info..thanks for sharing...your're a legend
Ganesh Hariharan
As suggested the best way is to have snmp of the switch,so that you can have historical events also of the switch port.for immediate assitanct use PRTG freeware with 10 sensors and check the events of the ports which your monitroing.
Hope to Help !!
Ganesh.H
Remember to rate the helpful post
