Cisco Call Manager 7.1.3 Unable to answer call on second line on 7962 when placing a call
Answered Question
Apr 26th, 2010
I have configured Cisco 7962 IP Phone with several lines. I am having a problem with this scenario
When I am making a call on line 1 of the cisco 7962 and a call rings on the second line, if I try to answer line 2 it cuts off the call on line 1.
Can this situation be fixed?
While initiating a call on line 1, should be able to answer incoming call on line 2 without disconnecting call on line1
Correct Answer by Jaime Valencia about 6 years 5 months ago
Does this happen to all phones and all phone models?
If you press answer softkey for the 2nd call does the active call drops? internal? external? both?
if this helps, please rate
Overall Rating: 5 (4 ratings)
Correct Answer
Jaime Valencia Tue, 04/27/2010 - 06:11
m-laing Tue, 04/27/2010 - 07:07
This happens for all phones deployed, Cisco CP-7942 and Cisco CP-7962 for internal and external calls.
Model Phone CP-7962
Line 1 ext 1000
Line 2  ext 1001
Line 3 ext 1002
User selects Line 1 and dials a number, while dialing the number on line 1 a call comes in on the second line
If line 2 is selected to answer the call, once this line is selected it automatically drops the call on line 1
Line1 call is in the ringing state and not answered
Tommer Catlin Tue, 04/27/2010 - 08:25
I have seen this before and it is expected behavior.  I could not figure out a work around for this.  I know what you are saying though, its more for admins who answer other lines from what I have seen in the past.   They are in the middle of placing a call or dialing the numbers and the phone is ringing.  They cant get to the line button to answer it if I remember correctly.
rob.huffman Tue, 04/27/2010 - 08:35
Hi Marsha,
Just to add-on to the great info from Java and TCAT (+5 points each my friends!)
This is expected behaviour in all IP Phone models with all CUCM versions. You would have to
be able to change the "Ring-Out" Softkey behaviour to keep line 1 active while intitiating a call
and still offer the "Answer" Softkey and this cannot be changed.
It kind of makes sense have to make a I complete my 1st Outgoing call or
take the new Incoming call. You can't do both in this scenario
Please support CSC Helps Haiti
m-laing Tue, 04/27/2010 - 08:57
Thank you for your assistance, I really hoped that Cisco had a solution to this problem as currently other (Nortel) systems are able to do this.
Apart from the option of completing the outgoing call first before answering the incoming one is there other option available.
I have an operator who is using the Cisco 7962 phones and this is now a big challenge.
Jaime Valencia Tue, 04/27/2010 - 09:01
+5 for you Rob, you're absolutely right
Just read the scenario you mentioned, and the problem is that in order for this to work the call is put on hold when it's established.
But since the call is not yet connected you cannot put it on hold. As Tcat and Rob mentioned this is WAD.
rob.huffman Tue, 04/27/2010 - 10:36
Hi Marsha,
Just wanted to let you know I tested this out on some Nortel
phones here to verify. We still run a hybrid system with CSE1000 (Nortel)
In my testing with 2616's and 3904's you can put call 1 on Line 1 on Hold before
the far end has answered and go ahead and answer call 2. Funny thing is I've
worked on the Nortel system for many years and never knew of this capability. I'm not sure
of it's value......if you did this the first caller would get MOH when they picked up and would likely
hang up. But, just thought I'd let you know what I found.
m-laing Tue, 04/27/2010 - 11:36
Hi Rob
There are some features like this which are automatically assumed to be a feature support by CUCM that are not. This is one of them.
The use of this feature is a valid one and as such I would request that this be supported in the next release of the software as this is a critical to the efficient operator of operators within an organizaion.
Thanks for your research
rob.huffman Tue, 04/27/2010 - 11:52
Hi Marsha,
I totally agree that if this is available on "Legacy" systems and your users
find it helpful, then it is a very valid request.(I'm sorry if I didn't come across that way
You should talk to your Cisco SE and account rep. and ask them to file a PER (Product
Enhancement Request) on your behalf.
