How to indentify the host
Apr 26th, 2010
on my network a particular host is using more Bandwith. What the show command i can use to identify which host is that and what the bankwith its using.
The network has the ASA connected to the internal router and the router is connected to the edge switch
Logesh
Ganesh Hariharan Mon, 04/26/2010 - 22:32
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Member's Choice, February 2016
Logesh
Hi Logesh,
Try configure ip accounting in router interface which is connected to local switch from where traffic is getting genrated,As The IP accounting command records the number of bytes (IP header and data) and packets switched through the system on a source and destination IP address basis. Only transit IP traffic is measured and only on an outbound basis; traffic generated by the router access server or terminating in this device is not included in the accounting statistics.
Check out the below link for the same :-
http://www.ciscofinancing.com/en/US/docs/ios/12_1/iproute/command/reference/1rdip.html#wp1018815
Hope to Help !!
Remember to rate the helpful post
Ganesh.H
lmanavalan Tue, 04/27/2010 - 00:12
Thanks for you reply....currely i just installed Netflow software on a host to collect the traffice information from the router.....will see how it go
Logesh
