Firewall Backup & restore
Apr 26th, 2010
hi everyone,
              I want to restore the backup of startup-config from old ASA 5520 to new ASA 5520. I was told that if I restore the backup all the password would not be restored and therefore I will have to maunally type each every passwords especially all the VPN passwords.
pls guide me
regards,
mangesh
dougtraser Thu, 05/06/2010 - 10:50
You should be able to use the copy command and copy from your startup-config to a TFTP server.
FW# copy startup-config tftp:
Address or name of remote host []?
Destination filename [startup-config?
1234 bytes copied in 5.67 secs
FW#
Then reverse the process to pull the configuration from the TFTP server to the new firewall.
