nv_done: unable to open "flash:/multiple-fs.new"[OK] on cisco WS-CBS3130X-S-F
dattx_fis2
I've got a new Cisco Catalyst WS-CBS3130X-S for Dell PowerEdge M1000e blade. When I save configuration by both command "write mem" and "copy run start" I got these:
Building configuration...
nv_done: unable to open "flash:/config.text.new"
nv_done: unable to open "flash:/private-config.text.new"
show flash
Directory of flash:/
%Error opening flash:/ (Invalid argument)
No space information available
I checked in Software Bug Toolkit ID CSCsq26410 but it seems not be able to help me because I dont use Stacking and my IOS is version 12.2(50)SE3 (cbs31x0-universal-mz.122-50.SE3.bin)
Is there any suggestion?
Thanks in advanced!
9 Replies 9
Ganesh Hariharan
show flash
Thanks in advanced!
Check command dir flash command to determine if there are any old exception crashinfo files that can be deleted or old images that are not in use.To free up space to write configuration into memory, issue the write memory command.
Hope to help !!
Ganesh.H
Thanks Ganesh but unfortunately that it doesn't work: I can't execute command dir flash: or dir flash1:
dir
dir flash
%Error opening flash:/flash (Invalid argument)
dir flash1:
Anyway, thanks alot again!
Dat
When you attempted to execute the "dir" command were you in enable mode (curser should be a "#" instead of a ">")?
dir
dir flash
dir flash1:
Dat
Hi Dat,
If the router/switch has a bad Flash, it will not be able to download the Cisco IOS software image. If you issue the show flash command, it will not be able to recognize the Flash.
Check out the below link
http://www.cisco.com/en/US/products/hw/switches/ps628/products_tech_note09186a0080169696.shtml
Hope to Help !!
Ganesh.H
Remember to rate Helpful post
We've just had exactly the same error message with a member of our 4 switch Catalyst 3750-E stack. Running the "fsck" command resolved it for us.
Hope this helps.
hello sir
i have 2970G SWITCH and i want to delete flash with  switch: mod
but its not work properly
its created an error
File "flash:config.text" not deleted -- invalid argument
i hop you help me in this metter thnks
This fsck command resolved my issue,thanks
I had the exact issue on my 3750x Running version c3750e-universalk9-mz.152-4.E10 with a stack of 4, only switch 3 was fine and could only do a sh dir of flash3: only, I ran the FSCK on each switch and now everything works fine,  Thanks much Flaming Badger!!
Hi;
You can check below URL that refer to IOS bug issue :
https://bst.cloudapps.cisco.com/bugsearch/bug/CSCsl06568/?referring_site=bugquickviewredir
Do not forget to rate the post
