Cisco VSS Dual Supervisor
Apr 27th, 2010
Dear All,
Whether  Cisco IOS Release 12.2(33)SXH1 will support dual supervisor (per box) for VSS. please help  by providing the info. Release note is not providing much info.
krahmani323 Tue, 04/27/2010 - 01:01
  • Silver, 250 points or more
Hello Pasad,
No. According to the following Q&A link (http://www.cisco.com/en/US/prod/collateral/switches/ps5718/ps9336/prod_qas0900aecd806ed74b.html)
Q. What are the  hardware and software requirements and restrictions for VSS?
Supervisor  Engine
Virtual Switching  Supervisor 720-10GE (VS-S720-10GE-3C and VS-S720-10GE-3CXL)
Note: Initial release  supports a single supervisor engine per virtual switch member  (or chassis). This restriction will be removed in a future software  release.
The current VSS is currently as follows (http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.2SX/configuration/guide/vss.html#wp1054558)
A VSS operates stateful switchover (SSO) between the active and standby  supervisor engines. Compared to standalone mode, a VSS has the following  important differences in its redundancy model:
•The active and standby supervisor  engines are hosted in separate chassis and use the VSL to exchange  information.
•The active supervisor engine controls  both chassis of the VSS. The active supervisor engine runs the Layer 2  and Layer 3 control protocols and manages the switching modules on both  chassis.
•The active and standby chassis both  perform data traffic forwarding.
If the active supervisor engine fails, the standby supervisor engine  initiates a switchover and assumes the active role.
Kind regards.
Karim
Reza Sharifi Wed, 03/30/2011 - 15:30
  • Cisco Designated VIP,
    2017 LAN
SXI4 image supports Dual Supervsor per chasssis in VSS.
Reza
kylerossd Mon, 07/08/2013 - 08:44
Reza,
Can you have redudant SUPs in only one of the VSS chassis?
Kyle
Joseph W. Doherty Mon, 07/08/2013 - 09:39
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
I haven't tried it, but since it's what you're left with if one of your quad sups fails, one would expect it to work.
