IP Phones 6900 series features
Apr 27th, 2010
Hi everybody,
I have an important project to implement where we want to position the new 6900 phones series (6941) on a CUCM 7.1(5).
I did not play with these new models yet, so I would like to guarantee some features compatibility, could you help me confirming these following points?
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman","serif";}
- Support of Extension Mobility (seems to be natively supported)
- Active monitoring/recording (using BIB) (seems to be supported since FW 8.5.4)
- TLS/SRTP (signaling and media encryption) (seems to be supported since FW 9.0.2)
- CTI support (Cisco Click-to-call widget...)
- Secure monitoring/recording (if roadmapped, I think CUCM 8.x will be needed)
- Multiple call per line (roadmapped?)
If someone already validated one of these features on CUCM 7.1.x with these 6900 phones, I would really appreciate your feedback.
Thank you for your help.
Best regards,
Yorick
Related Content
