Lobby access on WLC
Apr 27th, 2010
is there a way to access a lobby database on WLC by telnet?
Where can I find CLI command relative to lobby ambassador management?
Thank you very much
sschmidt Tue, 04/27/2010 - 08:45
On the controller the guest users and local net users are lumped into one.  To view them via the cli you would use the command "show netuser summary".
The users marked as Permanent are local net users and the ones marked as Guest are guest users.
To show more detail you can use the command "show netuser detail "
l.buschi Tue, 04/27/2010 - 09:23
Ok thank you very much,
please can you tell me if there is a way to create a user in lobby database via CLI?
