ICMP Error
Apr 27th, 2010
Recently I have been getting the following error message;
Denied ICMP type=8, code=0 from 10.3.70.113 on interface inside
Any Idea's how to resolve this?
Tahir
Jennifer Halim Tue, 04/27/2010 - 03:16
  • Cisco Employee,
I assume that you are trying to ping the inside interface of the ASA firewall?
If that is the case,  you need to configure the following:
icmp permit any inside
OR/ if you need to be more specific you can configure the following:
icmp permit 10.3.70.113 255.255.255.255 inside
tahirs001 Tue, 04/27/2010 - 03:24
Hi Halijenn,
This is happening automatically, ICMP has been disabled. This error is generating quite frequently from various IP's
Tahir
Jennifer Halim Tue, 04/27/2010 - 03:26
  • Cisco Employee,
The error is generated because as you advised icmp is disabled, hence you are getting the error on "deny" icmp echo.
tahirs001 Tue, 04/27/2010 - 03:31
This has just started to happen, ICMP has been disabled when we upgraded.
Will an access-list have triggered this off?
Tahir
Jennifer Halim Tue, 04/27/2010 - 03:34
  • Cisco Employee,
The error is triggered because you disable icmp, if you enable icmp, you will not see that error.
The error says "deny" the icmp packet, because you have disabled icmp after upgrade as you said.
