Automate Extension Mobility login for list of users
Apr 27th, 2010
  • Gold, 750 points or more
Is anyone aware of a script/program that can parse a list of phones, usernames and EM device profiles and automatically log users in?
This can be done on a per device basis using the URL below but I am looking for something that could parse a CSV file or similar.
http://<server>/emservice/jsp/Tools/sampleloginapp.jsp
Overall Rating: 4 (2 ratings)
Simon Machielse Thu, 05/06/2010 - 02:23
You can use BAT in UCM 6 and up I believe to login and logout users on a BULK. this supports CSV and can be scheduled.
If you are looking for a user based login search g00gle with the phrase "Cisco single sign on" and you should find a list of developers.
William Bell Thu, 05/06/2010 - 04:47
  • Purple, 4500 points or more
With BAT you can perform a bulk EM-logout as part of a phone update but I don't believe it supports a bulk login function.  You would need to leverage the EM API to accomplish this type of transaction.  The "sampleloginapp" is a demonstration of how this API works.
HTH.
Bill
