04-27-2010 03:57 AM - edited 02-21-2020 03:56 AM
Hi all,
This equipment is new and I'm experiencing too slowly when I connect via SSH, access privileged mode, or typing commands like "show run" for example.
At first glance there appears to be excessive consumption (CPU utilization for five seconds: 2% 1% one minute: 3% five minutes: 2%), but I am very worried and wanted to find a solution.
Does anyone know which may be due, and how could I fix it?
gw1-virtual#sh processes cpu sorted | exclude 0.00%
CPU utilization for five seconds: 2%/1%; one minute: 3%; five minutes: 2%
PID Runtime(uS) Invoked uSecs 5Sec 1Min 5Min TTY Process
174 1040000 225509114 0 0.23% 0.24% 0.23% 0 HQF Shaper Backg
114 952740000 11150632 85 0.15% 0.08% 0.07% 0 IP Input
23 424000 1089 389 0.15% 0.15% 0.03% 388 SSH Process
86 1384000 1808318 0 0.07% 0.02% 0.02% 0 BPSM stat Proces
Solved! Go to Solution.
04-28-2010 05:29 AM
Your cpu is 0-1%. The processes look normal and low.
I don't understand what your concern is.
PK
04-27-2010 04:22 AM
This is the output of "show interface G0/0" command:
GW-ABCD#sh int gigabitEthernet 0/0
GigabitEthernet0/0 is up, line protocol is up
Hardware is CN Gigabit Ethernet, address is12ws.xx (bia ssxx.xxss.yyyy)
Description: LAN ABCD
Internet address is xxx.yyy.z.yy/26
MTU 1500 bytes, BW 100000 Kbit/sec, DLY 100 usec,
reliability 242/255, txload 1/255, rxload 4/255
Keepalive set (10 sec)
Full-duplex, 100Mb/s, media type is RJ45
output flow-control is unsupported, input flow-control is unsupported
Last input 00:00:00, output 00:00:00, output hang never
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 3
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 1899000 bits/sec, 237 packets/sec
5 minute output rate 783000 bits/sec, 230 packets/sec
114910363 packets input, 579299624 bytes, 0 no buffer
Received 153712 broadcasts, 0 runts, 0 giants, 0 throttles
11940352 input errors, 5970176 CRC, 534560 frame, 0 overrun, 0 ignored
0 watchdog, 0 multicast, 0 pause input
109304271 packets output, 1527252245 bytes, 0 underruns
0 output errors, 0 collisions, 2 interface resets
0 unknown protocol drops
4 lost carrier, 0 no carrier, 0 pause output
I do not see SP or RP "drops" so rule out that the problem is in the LAN
gw1-virtual#sh int gigabitEthernet 0/0 switching
GigabitEthernet0/0 LAN MAATG
Throttle count 0
Drops RP 0 SP 0
SPD Flushes Fast 0 SSE 0
SPD Aggress Fast 0
SPD Priority Inputs 260607 Drops 0
04-27-2010 04:17 PM
~3% CPU is very low. You should not worry.
When you connect with ssh the device will generate RSA DH numbers and it is normal to spike your CPU a little.
But still 1-3% is very very low and you should not consider it as high CPU.
To check what processes take up your CPU do "sh process" twice with 30 sec difference and do the diff on the processes to see which one took up most of the cpu during the 30seconds.
PK
04-28-2010 01:21 AM
add the output. can not interpret. Can you help me ?
gw1-abcdl#sh processes cpu sorted | exclude 0.00%
CPU utilization for five seconds: 1%/0%; one minute: 1%; five minutes: 1%
5 493256000 132910 3711 0.39% 0.07% 0.05% 0 Check heaps
174 1072000 244871446 0 0.23% 0.23% 0.23% 0 HQF Shaper Backg
114 1025512000 11987107 85 0.07% 0.12% 0.09% 0 IP Input
23 704000 2981 236 0.07% 0.16% 0.04% 388 SSH Process
gw1-abcd#sh processes cpu sorted | exclude 0.00%
5 493268000 132916 3711 0.23% 0.05% 0.05% 0 Check heaps
174 1072000 244881725 0 0.23% 0.23% 0.23% 0 HQF Shaper Backg
110 404000 30648734 0 0.07% 0.03% 0.02% 0 IPAM Manager
114 1025568000 11987657 85 0.07% 0.12% 0.09% 0 IP Input
04-28-2010 05:29 AM
PK
04-28-2010 08:09 AM
Hi, I'm sorry for not having explained:
what I mean is if you think that the slowness is related to the consumption of CPU or anything else (bad configuration, etc.) related to this other thread.
https://supportforums.cisco.com/message/3057549#3057549
Thanks for your help
04-28-2010 08:25 AM
I don't think it is the CPU.
Please check the interface that you are ssh-ing for duplex mismatch with what it connects, and errors.
Also check for packet loss in the path to your computer.
Also if you are doing command authorization check if the ASA has connectivity issues to the ACS server.
These are what I would suspect.
PK
04-29-2010 12:12 AM
Ok,
I'll keep looking. Thanks for your help
