Need help in IOS for c4506
Apr 27th, 2010
Hello Experts,
I was searching for a IOS for our C4506 switch SUP II+ engine, with following features. I had searched in the software advisory on cisco.com but no help.
1. PBR with multiple tracking options
2. IP SLA
3. No EIGRP stub routing.
Appreciate your help in this.
Arabinda
glen.grant Tue, 04/27/2010 - 07:21
  • Purple, 4500 points or more
   Your only options for routing on a Sup II plus is  static , RIP, EIGRP stub .  To support other dynamic routing protocols like ospf , bgp, or full EIGRP you would have to change the supervisor to a different model.   You only 2 options for code and that is base and base with SSH support.  Pick the latest code version and check for bugs.
