BGP aggregation
Apr 27th, 2010
Guys i have two subnets as under and i want to aggregate them in BGP but dont know what
would be the aggregation address if someone plz help me out....secondly i have to put ip prefix list as well for these networks so what would be that like le 32 etc
192.68.72.160 /27
192.68.72.32 /28
Thanks guys
Giuseppe Larosa Tue, 04/27/2010 - 07:13
  • Hall of Fame,
    Founding Member
Hello Khan,
you need to write down in binary the last byte and you need to find out the last matching bit in base addresses
160 = 128 +32  ->  1010 0000
32                         0010 0000
the only possible aggregate that covers both IP prefixes but also other possible prefixes is:
192.168.72.0/24   because first bit of 4th byte is different in the two base addresses
this is called a non exclusive summary route
in BGP you can use
router bgp xx
aggregate-address 192.168.72.0 mask 255.255.255.0
if this is not acceptable for you, you should advertise the IP single subnets
Hope to help
Giuseppe
