VPN configuration on cisco 1941
Apr 27th, 2010
Hi all,
first time I try to create VPN between two Cisco routers, but unsuccessfully.
I have Cisco1941 and Cisco 2811, configuration on my 1941 router are:
router#sh run
Building configuration...
Current configuration : 5601 bytes
! Last configuration change at 17:01:49 PCTime Tue Apr 27 2010 by admin
version 15.0
no service pad
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname router
boot-start-marker
boot-end-marker
logging buffered 51200
logging console critical
aaa new-model
aaa authentication login exvpnxauth local
aaa authorization network ezvpnnetwork local
aaa session-id common
no ipv6 cef
no ip source-route
ip cef
no ip bootp server
redundancy
ip tcp synwait-time 10
ip ssh version 2
no ip rcmd domain-lookup
crypto isakmp policy 5
encr 3des
authentication pre-share
group 2
lifetime 28800
crypto isakmp key vpnpassword address 2.3.4.5
crypto ipsec transform-set STRONG esp-3des esp-sha-hmac
crypto map Cisco-vpn 10 ipsec-isakmp
set peer 2.3.4.5
set transform-set STRONG
set pfs group2
match address 122
interface Loopback0
ip address 20.20.20.20 255.255.255.255
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
interface GigabitEthernet0/0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip virtual-reassembly
duplex auto
speed auto
no mop enabled
interface GigabitEthernet0/0.1
encapsulation dot1Q 570
ip address 2.2.2.2 255.255.255.248
ip access-group 110 in
ip nat outside
no cdp enable
interface GigabitEthernet0/1
description internal-net
ip address 10.10.10.1 255.255.255.0
no ip redirects
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat inside
duplex auto
speed auto
no mop enabled
ip forward-protocol nd
ip nat inside source static 10.10.10.2 2.2.2.3
ip route 0.0.0.0 0.0.0.0 2.2.2.1
logging trap debugging
access-list 1 permit 10.10.10.0 0.0.0.255
access-list 10 permit 10.10.10.2
access-list 10 deny   any
access-list 110 permit tcp any any established
access-list 110 permit icmp any any
access-list 110 permit ip 10.10.10.0 0.0.0.255 any
access-list 110 permit tcp host 2.3.4.5 host 2.2.2.2
access-list 110 permit udp any any
access-list 110 permit gre any any
access-list 122 permit ip 10.10.10.0 0.0.0.255 10.3.0.0 0.0.255.255
no cdp run
control-plane
Whats is wrong in this config?
In logs I can not see any error about VPN.
Thanks.
Federico Coto F... Tue, 04/27/2010 - 12:15
The VPN (interesting traffic) should flow between these two networks:
10.10.10.0 0.0.0.255 and 10.3.0.0 0.0.255.255
Try to send traffic between these networks and please post the output of the following two commands:
sh cry isa sa
sh cry ips sa
Federico.
Zigmunds Vitins Tue, 04/27/2010 - 23:54
#sh cry isa sa
IPv4 Crypto ISAKMP SA
dst             src             state          conn-id status
IPv6 Crypto ISAKMP SA
#sh cry ips sa
interface: GigabitEthernet0/0.1
    Crypto map tag: vpn-test, local addr 2.2.2.2
   protected vrf: (none)
   local  ident (addr/mask/prot/port): (10.10.10.0/255.255.255.0/0/0)
   remote ident (addr/mask/prot/port): (10.3.0.0/255.255.0.0/0/0)
   current_peer 2.3.4.5 port 500
     PERMIT, flags={origin_is_acl,}
    #pkts encaps: 0, #pkts encrypt: 0, #pkts digest: 0
    #pkts decaps: 0, #pkts decrypt: 0, #pkts verify: 0
    #pkts compressed: 0, #pkts decompressed: 0
    #pkts not compressed: 0, #pkts compr. failed: 0
    #pkts not decompressed: 0, #pkts decompress failed: 0
    #send errors 0, #recv errors 0
     local crypto endpt.: 2.2.2.2, remote crypto endpt.: 2.3.4.5
     path mtu 1500, ip mtu 1500, ip mtu idb GigabitEthernet0/0.1
     current outbound spi: 0x0(0)
     PFS (Y/N): N, DH group: none
     inbound esp sas:
     inbound ah sas:
     inbound pcp sas:
     outbound esp sas:
     outbound ah sas:
     outbound pcp sas:
Zigmunds Vitins Wed, 04/28/2010 - 00:40
Hi all,
I found my mistake, I forgot to allow esp from peer IP.
Now VPN is up and running
Thanks.
