How to use two same extesion at UNITY
Answered Question
Apr 27th, 2010
Hi Folks,
I have a Unity Cisco Unity 5.0 Build 5.0(1). I need to create two users but they have the sma extesion 9413 but they are in different location (one in Santos the other in the São Paulo).
How can I do to the UNITY distinguish this?
Thank you very much
Correct Answer by Jaime Valencia about 7 years 2 days ago
You can't. Unity needs unique numbers.
You would need to create a new VM profile and add an extra digit in the VM mask and use the same DN in Unity.
One of them needs to turn into a 5 digit DN in Unity.
java
if this helps, please rate
www.cisco.com/go/pdihelpdesk
Overall Rating: 5 (1 ratings)
Correct Answer
Jaime Valencia Tue, 04/27/2010 - 08:10
  • Cisco Employee,
  • Hall of Fame,
    2011
java
