04-27-2010 08:21 AM - edited 03-04-2019 08:17 AM
I'm trying to give RDP priority over web traffic. This is what I have so far:
class-map match-any scum
match protocol http
class-map match-any RDP
match access-group name RDP
policy-map die-scum
class scum
police cir 8000 pir 9000
conform-action set-prec-transmit 0
exceed-action drop
policy-map Inbound
class RDP
police cir 9000000 pir 10000000
conform-action transmit
exceed-action set-prec-transmit 0
violate-action drop
service-policy die-scum
ip access-list extended RDP
permit tcp any any eq 3389
If I put the policy-map Inbound on my WAN interface as an input filter, it does nothing. However, if I put the policy-map die-scum on my WAN interface as an input filter, web traffic almost grinds to a halt (which is what I want).
What am I doing wrong here?
Solved! Go to Solution.
04-27-2010 10:11 AM
You are only allowed to apply a policy to an interface and you have two policies.
Ideally, you should have this configuration:
policy-map inbound-internet
class scum
exceed-action drop
class RDP
violate-action drop
interface WAN0/0
service-policy in inbound-internet
Edison
04-27-2010 10:11 AM
class scum
exceed-action drop
class RDP
violate-action drop
interface WAN0/0
Edison
04-27-2010 10:29 AM
The service-policy die-scum in my policy-map Inbound doesn't run the policy-map die-scum as well?
policy-map Inbound
class RDP
violate-action drop
04-27-2010 10:43 AM
That feature requires an IOS that support HQF
http://www.cisco.com/en/US/docs/ios/qos/configuration/guide/qos_frhqf_support.html
For other IOSes, you are limited to class class-default on the parent class.
Edison
04-27-2010 12:01 PM
Thanks for your answers. I tried it the way you suggested and it worked.
