Create account with privilegious of User
Answered Question
Apr 27th, 2010
Hi Guys,
My Customer have a solution IPCCX version 5.0.2 and He would like know If is possible create a account with privilegiou of user (Read Only)
Wilson Santana
Correct Answer by Phuong Hoai Huynh about 6 years 9 months ago
Hi Wilson
There isnt any user permission for read only acess in UCCX 5.0
As per the administration guide you only have 3 types of users:
Administrator -- Full access to UCCX system.
Supervisor Privileges - Breaks down into 3 other subclass depending on writes and license, but all results are for either administering teams/csq/skill or reviewing reports/monitoring
Historical Reports User Privileges - View historical reports.
Refer to the following weblink for more infomration:
http://www.cisco.com/en/US/partner/products/sw/custcosw/ps1846/products_installation_and_configuration_guides_list.html
Document: Cisco CRS Administration Guide 5.0(1)
Overall Rating: 5 (1 ratings)
Aaron Harrison Tue, 04/27/2010 - 11:18
Can you clarify what priveleges you want?
Do you mean to the DB? To the repository? The server?
Aaron
wilsonsant Tue, 04/27/2010 - 11:28
Hi Aaron,
The Customer would like to see for example, the quantity user created, where the IPCCX is to do the backup, the profile of user, etc...
Wilson Santana
Correct Answer
Phuong Hoai Huynh Tue, 04/27/2010 - 23:03
Hi Wilson
