AnyConnect Gina - Cisco IPSec Gina - Compatible?
Apr 27th, 2010
My client is currently using the Cisco IPsec client with the Gina installed. In the coming months they will be migrating to the new AnyConnect client with the gina. I know its possible to have both clients installed on the same system, but is it possible to have both ginas? Will one overwrite the other? I need to understand the compatibility if any.
Thanks!
jan.nielsen Wed, 05/05/2010 - 10:26
I doubt it, gina's are daisy chained in the windows subsystem, so they would probably both start if they are able to work at all together
