Warning message
Cobra Port Usage
Answered Question
Apr 27th, 2010
I have UC 7.X and backing it up Cobra, but we are now going to back it up with another server and we have a firewall in the middle. I need to know what ports need to be open so I can tell the firewall group.
Correct Answer by David Hailey about 7 years 3 months ago
Ah, my bad - I overlooked the UC which you intended to mean Unity Connection.  I had Unity stuck in my head for some reason.  So, forgive that transgression and see below:
I see what you're saying now.  The new backup box will be separated by a firewall between it and Unity Connection. COBRAS sets up an ODBC connection to the CUC database via the DB Proxy server on port 20532.  You can get further info here:
http://www.ciscounitytools.com/Applications/General/COBRAS/Help/COBRAS.htm#_Toc258831590
Hailey
Please rate helpful posts!
Overall Rating: 5 (3 ratings)
David Hailey Tue, 04/27/2010 - 09:28
  • Purple, 4500 points or more
Carlo,
Here's actually what you would need to know:
COBRAS Export will still need to be installed on the Unity server.  What you will want to do is to backup to an off-box location (i.e., another server).  So, when you do this you will configure COBRAS to back-up your server to a shared folder location on the other server - you should use the full UNC path for the shared folder.
On the firewall side, you'll need to open up the Windows File and Print Sharing ports (e.g., SMB ports).  These are standard ports - nothing to do with COBRAS itself.
Hailey
CARLO CALABRESE Tue, 04/27/2010 - 09:42
UC7 is on a lynx box. The COBRAS software runs on the windows box. How do you map a drive to the lynx box?
Correct Answer
David Hailey Tue, 04/27/2010 - 09:52
Hailey
CARLO CALABRESE Tue, 04/27/2010 - 09:55
That's what I needed. Only one port? I'm working on CER and other CUOM and there are pages of port on thoese.
Thanks for the help.
Carlo
David Hailey Tue, 04/27/2010 - 10:04
Well, Carlo - here is an important question for you. You only referenced COBRAS in your post. There is also DRS (Disaster Recovery System) which is the primary backup solution (usually) for CUC. Are you doing all of your backups with COBRAS or are you using DRS as well?
Hailey
CARLO CALABRESE Tue, 04/27/2010 - 10:13
We do the nightly backup with CUC and sftp it to a server for the Data Center to back up that server. That's and easy port (22). I like doing the COBRAS backup so I can restore someone's lost messages.
When I get this done, My next project is to get IMAP connection from the Internet. I'm going to have fun getting that one past security.(LOL)
Carlo
David Hailey Tue, 04/27/2010 - 10:17
Ok, cool. I was going to say that I can give you a list of all the CUC ports - but it didn’t sound like you needed that. I'd test the backup with COBRAS and if you have issues with message backup, you may need to open up SMTP (probably not desirable) but you'll just have to test and see. I know that during an IMPORT with COBRAS, message import is straight SMTP but that involves actually putting messages into a user's mailbox. Export is just pulling the messages to a backup database.
Hailey
Related Content
