Jerry Ye Tue, 04/27/2010 - 21:45
  • Cisco Employee,
Assuming you are talking about Nexus 7000. In order to control SSH to vty like IOS, you have to configure CoPP in  the default VDC. There is an enhanced bug filed to correct this problem  in the later release - CSCsq20638.
Here is the example to allow ssh to the Nexus from 10.10.10.0/24 network
ip access-list copp-system-acl-allow
10 remark ### ALLOW SSH
20  permit tcp 10.10.10.0/24 any eq 22
30 remark ### ALLOW SNMP
40  permit udp 10.10.20.0/24 any eq snmp
... ... (to include snmp, NTP,  TACACS+, etc)
ip  access-list copp-system-acl-deny
  10 remark ### this is a  catch-all to match any other traffic
  20 permit ip any any
class-map  type control-plane match-any copp-system-class-management-allow
   match access-group name copp-system-acl-allow
class-map type  control-plane match-any copp-system-class-management-deny
  match  access-group name copp-system-acl-deny
policy-map type control-plane  copp-system-policy
    class copp-system-class-management-allow
         police cir 60000 kbps bc 250 ms conform transmit violate drop
     class copp-system-class-management-deny
        police cir 60000  kbps bc 250 ms conform drop violate drop
control-plane
  service-policy  input copp-system-policy
HTH,
jerry
Muhammed AKYUZ Tue, 04/27/2010 - 23:33
Thanks for the answer but, control-plane does not come with configure. I want to use this command under vdc..
Jerry Ye Wed, 04/28/2010 - 05:36
  • Cisco Employee,
Please look at bug ID CSCsq20638, attaching access-list under line vty is not an option right now, the workaround is to use CoPP.
jerry
Jerry Ye Thu, 04/29/2010 - 15:02
  • Cisco Employee,
If you want me to take a look, you can post it here. If you do post it, please put the output in a text file. Also, please indicate the host IP address you want to permit.
jerry
