Using an ASA 5505, how can I prioritize normal web surfing over streaming, file sharing, etc?
Apr 27th, 2010
I assume this can be done with QOS.  I want all internet traffic that is not normal web browsing to be a lower priority so that streaming, IM, and file sharing do not slow down work related browsing.  Please provide some sample code to do it.
Thanks.
-Ryan
astripat Tue, 04/27/2010 - 12:29
Hi Ryan,
Here I send you a configuration example how to setup QoS for Web traffic based on ACL's.
Permits outbound web port 80
access-list 105 permit tcp any any eq 80
ASA(config-cmap)#class-map Web-OUT
ASA(config-cmap)#match access-list 105
ASA(config-cmap)#policy-map qos
ASA(config-pmap)#class Web-OUT
ASA(config-pmap-c)#priority
ASA(config-pmap-c)#service-policy qos interface outside
ASA(config)#priority-queue outside
ASA(config-priority-queue)#queue-limit 2048
ASA(config-priority-queue)#tx-ring-limit 256
In order for you to check the QoS working here you have the show commands:
show service-policy interface outside
show service-policy priority
show priority-queue statistics outside
Ashu.
Panos Kampanakis Tue, 04/27/2010 - 16:07
  • Cisco Employee,
You would need to change astripat's config a little.
When prioritizing traffic you need to police the rest in order for prioritization to work.
Here is an example how to do it https://supportforums.cisco.com/docs/DOC-1230#Traffic_Policing_with_Prioritization. For policing I would suggest to police the rest of the traffic to the speed that you would give non-http traffic.
I hope it helps.
PK
