OSPF state down but neighbor Pingable
Apr 27th, 2010
Hi All,
         I have a strange problem on our network with a router 7200 series having a P-2-P interfaces to other locations.
The interfaces went down and come back up but OPSF show state down, while sh ip int brief shows interfaces up.
Debug ip ospf show exchanging hellos but sh ip ospf int XX, indicated that no ospf traffic is passing through.
Will appreciate an urgent help to this regard.
Thanking you all in advance,
Olugbenga.Abiodun Tue, 04/27/2010 - 12:35
     Thanks for your reply. But what do you mean by "port the show run int xx and show int xx from both ends?".
sameer.mulgund Tue, 04/27/2010 - 12:56
Please furnish with configuration of OSPF and sho ip int ospf output for further diagnosis.
Gaurav Gambhir Tue, 04/27/2010 - 13:37
xx means the interfaces that are directly connected b/w the devices on which you are running ospf.
for example
show run int f0/0 (from R1 and R2)
show int f0/0 (from R1 and R2)
