Directing traffic through McAfee SmartFilter
bghobadi2
Hello All-
How can I configure my ASA or router to send the web traffic to McAfee smartfilter server before the user can browse the Internet
I can get out to the internet bypassing the proxy.  Now the next step is to see how I get smartfilter working
This is what I put on my router
ip nat inside source list NatAccessList interface Ethernet1 overload
ip access-list extended NatAccessList
permit ip 10.0.0.0 0.255.255.255 any
Interface e1
Ip nat outside
Interface e0
Ip nat inside
Bo
astripat
Hi Bo,
You can configure url filtering on the ASA so that the request are first sent to the filtering server before it can be processed. The ASA supports N2H2 or websense for filtering. This can be configured as follows:
I am assuming that the ip address of the filtering server is 10.0.1.1 and it is located on the inside.
Using N2H2, the following example filters all outbound HTTP connections except those from the 10.0.2.20 host:
hostname(config)# url-server (inside) vendor n2h2 host 10.0.1.1
hostname(config)# filter url http 0 0 0 0
hostname(config)# filter url except 10.0.2.20 255.255.255.255 0 0
Using Websense, the following example filters all outbound HTTP connections except those from the 10.0.2.20 host:
hostname(config)# url-server (inside) vendor websense host 10.0.1.1 protocol TCP
version 4
If you want to filter https traffic also, then we would need the following as well
filter https 0 0 0 0 0
Also, it would be best to use the "allow" keyword at the end of the filter statements, so that if the filtering server goes down, the internet access is not lost, as follows:
filter url http 0 0 0 0 allow
Ashu
Hi Ashu,
I will get it try.
Thanks a lot.
Bo
