Warning message
Cannot get IOS Root CA to run
Apr 27th, 2010
  • Bronze, 100 points or more
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin;}
I am trying to run the IOS CA to serve as root to two subordinate CA’s on my DMVPN hubs.  I am using a 2650XM on IOS image c2600-advsecurityk9-mz.124-15.T12.bin, and am following the procedures in both http://www.cisco.com/en/US/docs/solutions/Enterprise/Security/PKI-security.html and the Cisco IOS Security Configuration Guide http://www.cisco.com/en/US/customer/docs/ios/sec_secure_connectivity/configuration/guide/12_4t/sec_secure_connectivity_12_4t_book.html section(s) on PKI.  I can get the CA running but ONLY if I do not configure ‘database url <url>’ (and presumably ‘cdp-url’)
I have tried using ftp:, and http: for ‘database url’ but I always get the server status of
Certificate Server root-ca:
    Status: disabled, Storage not accessible
and messages similar to “%PKI-3-CS_CRIT_STORAGE: Critical certificate storage, ftp://<username>:<password>@<ftp-server>/0x1.crt, is inaccessible, server disabled.” When I’m using ftp.  No message is issued when using http but the server status is the same.  And, the cert server appears to write the files 0x1.cnm and 0x1.crt, and the root-ca.ser file to the ftp server but still says storage is inaccessible.
Here is the no ‘database url’ configs that works:
crypto pki server root-ca
database level complete
database archive pkcs12 password 7 15361202377928311A
grant auto rollover ca-cert
grant auto
lifetime certificate 730
lifetime ca-certificate 750
auto-rollover 90
crypto pki trustpoint root-ca
revocation-check crl none
rsakeypair root-ca
crypto pki certificate chain root-ca
certificate ca 01
  30820302 308201EA A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  12311030 0E060355 04031307 726F6F74 2D636130 1E170D31 30303432 37323130
<lines deleted>
  94D7B595 3C35C1A1 9D0BAA22 E92C40BD D7DE6C1F 92BD1285 534817FC 62B4CBCF
  8EB659B5 5C3C
        quit
(I don’t think the rest of the config is needed, but ntp is configured and active as is the http server).
rsdpki1#sh crypto pki server
    Status: enabled
    State: enabled
    Server's configuration is locked  (enter "shut" to unlock it)
    Issuer name: CN=root-ca
    CA cert fingerprint: ACFF6E7F 7A87AB31 21BF7222 314D3BA9
    Granting mode is: auto
    Last certificate issued serial number: 0x1
    CA certificate expiration timer: 14:08:26 PDT May 16 2012
    CRL NextUpdate timer: 20:08:56 PDT Apr 27 2010
    Current primary storage dir: nvram:
    Database Level: Complete - all issued certs written as <serialnum>.cer
    Auto-Rollover configured, overlap period 90 days
    Autorollover timer: 13:08:26 PST Feb 16 2012
rsdpki1#sh crypto pki certificates
CA Certificate
  Status: Available
  Certificate Serial Number: 0x1
  Certificate Usage: Signature
  Issuer:
    cn=root-ca
  Subject:
    cn=root-ca
  Validity Date:
    start date: 14:08:26 PDT Apr 27 2010
    end   date: 14:08:26 PDT May 16 2012
  Associated Trustpoints: root-ca
rsdpki1#sh crypto key mypubkey rsa
% Key pair was generated at: 14:01:09 PDT Apr 27 2010
Key name: root-ca
Storage Device: not specified
Usage: General Purpose Key
Key is exportable.
Key Data:
  30820122 300D0609 2A864886 F70D0101 01050003 82010F00 3082010A 02820101
<lines removed>
  3F020301 0001
% Key pair was generated at: 14:01:16 PDT Apr 27 2010
Key name: root-ca.server
Temporary key
Usage: Encryption Key
Key is not exportable.
Key Data:
  307C300D 06092A86 4886F70D 01010105 00036B00 30680261 009E1CF0 EE0A4456
<lines removed>
  D92FACAB 7780169C 90B77FAF 92026085 F663353D 29CD8018 87020301 0001
rsdpki1#sh crypto key pubkey-chain rsa
Codes: M - Manually configured, C - Extracted from certificate
Code Usage         IP-Address/VRF         Keyring          Name
C    Signing                              default          X.500 DN name:
                              cn=root-ca
rsdpki1#sh crypto pki certificates storage
Certificates will be stored in nvram:
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin;} rsdpki1#
However, when I clear that all out and reconfigure it with an ftp: database, I get:
database archive pkcs12 password 7 052F1F01121F4D1C2B
grant auto
cdp-url ftp://ssdftp1/rsdpki1_generated.crl
auto-rollover 90
database url ftp://ssdftp1
database username ftp4ios password <removed>
rsakeypair root-ca
And show xxx shows:
    Status: disabled, Failed to generate selfsigned CA certificate
    State: check failed
    CA cert fingerprint: -Not found-
    Last certificate issued serial number: 0x0
    CA certificate expiration timer: 14:24:47 PDT May 16 2012
    CRL not present.
    Current primary storage dir: ftp://ssdftp1
% Key pair was generated at: 14:23:18 PDT Apr 27 2010
Key name: root-ca
Key is exportable.
Key Data:
<lines removed>
  63020301 0001
% Key pair was generated at: 14:23:25 PDT Apr 27 2010
Temporary key
Key Data:
  307C300D 06092A86 4886F70D 01010105 00036B00 30680261 00E514E6 0770D50A
<lines removed>
rsdpki1#  (I skipped the ‘sh crypto pki counters’)
But the files are written to the ftp server and appear fine.  Can anyone tell me the rules for ‘database url’ and/or ‘cdp-url’?  The “PKI Service for Large Scale IPSec Aggregation” document (first url) shows both ftp: and http: examples.  As I say, I *think* I have the ftp specified correctly because the files are written.  But I have no idea what the requirements are for the http server – do I need Web-DAV or something?
Thanks in advance.
PAUL TRIVINO
Sr. Network Engineer
jan.nielsen Wed, 05/05/2010 - 10:27
  • Gold, 750 points or more
did you try nvram or flash as url location ?
PAUL TRIVINO Thu, 05/06/2010 - 11:45
I did but that's the problem - the documentation says you can use 'any IOS-supported file system' and the DMVPN docs show several examples using 'ftp://...' and 'http://...'  But I could not get anything except Flash: to work.  I had to move the root-ca to a different router with a CF card.
plemieux72 Sat, 09/18/2010 - 09:05
Ran into same issue on a 2621XM CA server running advanced security IOS 12.4(15)T8.
I rebooted the router, and the CA service runs fine until I looked into the info request database, and approved the cert for a spoke, I got the following:
cry pki ser [removed] grant all
% Failed to process enrollment request. The request #1 is deleted.
...and in the log:
Sep 18 12:23:07.203: %PKI-3-CS_CRIT_STORAGE: Critical certificate storage, nvram:0xD.cnm, is inaccessible, server disabled.
Sep 18 12:23:07.211: %PKI-6-CS_DISABLED: Certificate server now disabled.
Have you found any resolution or root cause?
Thanks!
ken.grabarski Wed, 02/18/2015 - 08:48
Performed the following on a 2811 to resolve.
CA Server:
Create username/domain
Enable HTTP
Generate rsa key
crypto pki server ks
 grant auto
 lifetime certificate 180
 lifetime ca-certificate 7305
 database url flash:
 no shut
