PAP2T : answering machine hangs up
maximebourassa
I'm trying to make my answering machine work with my PAP2T. When I let an incoming call ring, my answering machine will pick up the call, play the greeting message, and then will simply hang up instead of recording the caller's message, just as if the caller already had hung up. What settings of the PAP2T should I try to adjust to avoid this?
Thanks!
maximebourassa
Actually no wonder no ones gets this problem. Once I correctly configured the number of minutes for the messages callers are leaving properly, the problem "disappeared". eheh silly me.
