CUC 7.1(3b) - 'set cuc ldapfilter .....'
Answered Question
Apr 27th, 2010
We're looking to filter our LDAP directory in CUC 7.1(3b) to only pull in accounts where the 'ipPhone' field contains something (or is not null).
We've been able to successfully implement this in CUCM, so that our Corporate Directory only lists AD accounts with the ipPhone field populated.
According to guides we've found online the command from CLI is, 'set cuc ldapfilter {insert filter}'
The syntax we're trying to use is:
set cuc ldapfilter '(&(objectclass=user)(!(objectclass=Computer))(!(UserAccountControl:1.2.840.113556.1.4.803:=2))(ipPhone=*))'
The problem is that the CUC CLI removes the ampersand (&) from the beginning of the string, so we end up with the following if we paste in the above filter:
set cuc ldapfilter '((objectclass=user)(!(objectclass=Computer))(!(UserAccountControl:1.2.840.113556.1.4.803:=2))(ipPhone=*))'
Has anyone successfully implemented LDAP filtering in CUC, if so can you please post a sample syntax?
Or, does anyone know how to type/enter an ampersand (&) in CUC CLI?
Correct Answer by William Bell about 6 years 11 months ago
I believe that your syntax is incorrect.
From this guide:  http://www.ciscosystems.com/en/US/docs/voice_ip_comm/cucm/cli_ref/7_1_3/cli_ref_713.html#wp39913
The 'set cuc ldapfilter' is a wizard based command.  For example:
admin:set cuc ldapfilter
Please select the LDAP server type for which you wish to set the filter:
1 Microsoft Active Directory
2 Netscape or Sun ONE LDAP Server
3 OpenLDAP
4 Microsoft Active Directory Application Mode
Selection: 1
Current filter:
(&(objectclass=user)(!(objectclass=Computer))(!(UserAccountControl:1.2.840.113556.1.4.803:=2)))
New Filter:
Filter updated successfully.
admin:
The items in blue and bold represent data you would input.
I just tested this on my 7.1(3b) lab system and the ampersand is not lost.  So, try entering "set cuc ldapfilter" by itself and hit enter.  Follow the wizard and see if you are still having problems.
HTH.
Bill
Overall Rating: 5 (2 ratings)
Correct Answer
William Bell Tue, 04/27/2010 - 16:57
  • Purple, 4500 points or more
3 OpenLDAP
Selection: 1
Current filter:
New Filter:
admin:
HTH.
Bill
david.kelsen Tue, 04/27/2010 - 17:21
Awesome!
I just applied the filter successfully following your guide.
It wasn't clear in the Cisco Guides I'd read that the command 'set cuc ldapfilter' was a wizard.
Thanks so much for your help William.
Cheers,
Dave.
satish rawat Wed, 06/16/2010 - 07:06
Hi Dave,
I noticed you sucessfully created custom filter in CUCM & wanted to check if you can provide more details to me. I am running CUCM 5.1.3.
i followed the steps mentioned at below forum but i am stuck becuase i am getting file not found error.
http://uccert.wikidot.com/forum/t-134148
C:\ccmUpgrade> java -cp .\classes;.\lib\saaj-api.jar;.\lib\saaj-impl.jar;.\lib\m
ail.jar;.\lib\activation.jar;.\lib\jaxm-api.jar;.\lib\jaxm-runtime.jar;.\lib\xer
cesImpl.jar;.\lib\xml-apis.jar AxlSqlToolkit -username=ccmapplication -password=
cisco -host=10.236.18.17 -input=LDAPFilter.xml
java.io.FileNotFoundException: LDAPFilter.xml (The system cannot find the file s
pecified)
at java.io.FileInputStream.open(Native Method)
at java.io.FileInputStream.(Unknown Source)
at AxlSqlToolkit.execute(AxlSqlToolkit.java:188)
at AxlSqlToolkit.main(AxlSqlToolkit.java:244)
any idea what i am missing, i verified xml filename but it may be something on my sql command. Below is content of my sql commands under xml file. can you  check what i am missing
<?xml version="1.0" encoding="UTF-8"?>
query CDATA #IMPLIED
  update CDATA #IMPLIED
please let me know if you can provide some easy seteps to do this.
thanks
Aaron Harrison Wed, 06/16/2010 - 07:11
  • Community Spotlight Award,
    Member's Choice, May 2015
The app isn't finding your LDAPFilter.xml file (as the error states).
In the -input parameter, specify the full path:
-input=c:\ccmupgrade\LDAPFilter.xml
Aaron
Please rate helpful posts...
satish rawat Wed, 06/16/2010 - 07:21
Hi Aaron,
Thanks for the quick response !
i tried using the file path but ends up in same error.
see the output from my command prompt
C:\ccmUpgrade>java -cp .\classes;.\lib\saaj-api.jar;.\lib\saaj-impl.jar;.\lib\ma
il.jar;.\lib\activation.jar;.\lib\jaxm-api.jar;.\lib\jaxm-runtime.jar;.\lib\xerc
esImpl.jar;.\lib\xml-apis.jar AxlSqlToolkit -username=ccmapplication -password=c
isco -host=10.236.18.17 -input=test.xml
[Fatal Error] :13:48: The entity name must immediately follow the '&' in the ent
ity reference.
org.xml.sax.SAXParseException: The entity name must immediately follow the '&' i
n the entity reference.
        at org.apache.xerces.parsers.DOMParser.parse(Unknown Source)
C:\ccmUpgrade>
C:\ccmUpgrade>
C:\ccmUpgrade>
select * from ldapfilter where tkldapserver=1
Sending message...
http://schemas.xmlsoap.org/soap/envelope/">
OAP-ENV:Header/>se
lect * from ldapfilter where tkldapserver=1dy>
Positive response received.
http://schemas.xmlsoap.org/soap/envelope/" SO
AP-ENV:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/">
r/>http://www.cisco.com/A
XL/API/1.0" xmlns:xsi="http://www.cisco.com/AXL/API/1.0" sequence="1276697871719
">c8b4c680-ead1-43c0-a264-27da8142c5391<
/tkldapserver>(&(objectclass=user)(!(objectclass=Computer))(!(UserAc
countControl:1.2.840.113556.1.4.803:=2)))LQueryResponse>
C:\ccmUpgrade>
C:\ccmUpgrade>
C:\ccmUpgrade>
C:\ccmUpgrade>
C:\ccmUpgrade>
C:\ccmUpgrade>
C:\ccmUpgrade>
C:\ccmUpgrade>
C:\ccmUpgrade>
C:\ccmUpgrade>
isco -host=10.236.18.17 -input=c:\ccmupgrade\LDAPFilter.xml
java.io.FileNotFoundException: c:\ccmupgrade\LDAPFilter.xml (The system cannot f
ind the file specified)
Aaron Harrison Wed, 06/16/2010 - 07:50
Where is your LDAPFilter file? Is it in c:\ccmupgrade?
The file you attached to the post earlier is named "LDAP Filter.xml" (with a space in the middle). If your file on disk has the space, rename it to remove the space.
Aaron
satish rawat Wed, 06/16/2010 - 08:42
Yes the file is in C:\ccmUpgrade
see i have tried diffrent combinations and it still errrors, i think this has something to do with contents of xml file.
notice when i used a diffrent filename( test.xml) it didnt error though the path mentiond doesnt have C:\ccmUpgrade
isco -host=10.236.18.17 -input=c:\ccmupgrade\LDAP Filter1.xml
AxlTestDriver (Java) parameters and options:
  -username=: use the specified username instead of default
  -password=: use the specified password instead of default
  -host=: use the specified hostname
  -port=: use the specified portnumber
  -input=: use the specified file as the source of the sql statements
  -output=: use the specified file as the destination of the AXL respo
nses
isco -host=10.236.18.17 -input=c:\ccmupgrade\LDAPFilter1.xml
java.io.FileNotFoundException: c:\ccmupgrade\LDAPFilter1.xml (The system cannot
find the file specified)
C:\ccmUpgrade>
C:\ccmUpgrade>
isco -host=10.236.18.17 -input=LDAPFilter1.xml
java.io.FileNotFoundException: LDAPFilter1.xml (The system cannot find the file
specified)
isco -host=10.236.18.17 -input=LDAP Filter1.xml
nses
C:\ccmUpgrade>
in  order to rule out that it is issue with file pathname or file name i used a diffrent filename ( just for  testing ) and didnt error.
Sending message...
OAP-ENV:Header/>se
XL/API/1.0" xmlns:xsi="http://www.cisco.com/AXL/API/1.0" sequence="1276702654499
satish rawat Wed, 06/16/2010 - 08:46
if i  rename to LDAFiter.xml to test.xml i get below error:
specified)
C:\ccmUpgrade>
ity reference.
Aaron Harrison Wed, 06/16/2010 - 08:52
OK - now you are getting somewhere.
The file is now found, however in XML '&' is a special character. It needs to be escaped by replacing the & in your LDAP query string with &
So an example would be:
Aaron
Please rate helpful posts and mark answered questions that you've got a satisfactory response from to help identify useful content in the forums...
https://supportforums.cisco.com/docs/DOC-6212
Aaron Harrison Wed, 06/16/2010 - 08:47
In my last post I suggested you rename the file, not use a space in the parameter.
If you put a space in the parameter it probably won't work, as it will see the space as the end of the filename. Your other test filenames don't have spaces...
FileNotFoundException means just that; it doesn't matter what the contents of the file are because the app can't find the file.
satish rawat Wed, 06/16/2010 - 09:09
thanks aaron,
now when i replaced & with &amp i am getting another error:
[Fatal Error] :13:51: The reference to entity "amp" must end with the ';' delimi
ter.
org.xml.sax.SAXParseException: The reference to entity "amp" must end with the '
;' delimiter.
sorry i  have not background to sql or vb  , any idea where should this delimiter be inserted.
Aaron Harrison Wed, 06/16/2010 - 09:23
Looks like you have replaced & with &amp rather than &
You need the ; as well.
satish rawat Wed, 06/16/2010 - 09:55
Thanks Aaron for  your valuable help. the script fiinally works.
Now when i look at sample.response file for results it says fatal error ( syntex error).
any idea what is wrong with my query
attaching the response file
Aaron Harrison Wed, 06/16/2010 - 10:05
You have :
update ldapfilter set filter = ='(....
two = =
it should start:
update ldapfilter set filter = '(....
Aaron
satish rawat Wed, 06/16/2010 - 10:22
Hi Aaron,
Thanks  for all your help. I figured out the issue and rectificed my SQl query
see the output  from CUCM CLI:
admin:run sql select * from ldapfilter where tkldapserver=1
pkid                                 tkldapserver filter
c8b4c680-ead1-43c0-a264-27da8142c539 1            (&(objectclass=user)(!(objectclass=Computer))(!(UserAccountControl:1.2.840.113556.1.4.803:=2))(|(telephonenumber=2*)(telephonenumber=3*)( telephonenumber=4*)(telephonenumber=5*)(telephonenumber=6*)(telephonenumber=7*)( telephonenumber=8*)))
admin:
what would be my next  step  is my CUCM ready to import users per this filter. what else do i need to setup in CUCM.
there seems to be not a document available to describer the steps on cisco.com
anyway
thanks for your help !!
Aaron Harrison Wed, 06/16/2010 - 11:40
It's not documented on Cisco.com as it's not supported. Version 8 allows you to do this via the GUI, which is supported.
Take a look at this post and the article that Bill wrote : https://supportforums.cisco.com/message/3047630?tstart=0
Basically if all is well you need to restart the DirSync service for the change to take effect, and then do a resync.
Aaron
satish rawat Thu, 06/17/2010 - 08:10
Hi Aaron,
Thanks for your help yesterdday.
I have one more questions maybe you can help.
I needed to create a LDAP query so that i can search users with telephone no  starting with 5 and any four digits. my current query states 5* and this will match 5 and any no of digits. Do you have any idea how to do this. here is my sql query for your  refrence
filter ='(&(objectclass=user)(!(objectclass=Computer))(!(UserAccountControl:1.2.840.113556.1.4.803:=2))(|(telephonenumber=2*)(telephonenumber=3*)(telephonenumber=)( telephonenumber=4*)(telephonenumber=5*)(telephonenumber=6*)(telephonenumber=7*)( telephonenumber=8*)))' where tkldapserver=1"/>
Aaron Harrison Thu, 06/17/2010 - 14:08
Try using nested greater than/less thans... I seem to recall doing this at some point but not really in a position to test:
=50000)(telephonenumber<=59999))(telephonenumber=6*)(telephonenumber=7*)( telephonenumber=8*)))' where tkldapserver=1"/>
Aaron
satish rawat Thu, 06/17/2010 - 15:31
Thanks Aaron,
Can you check if below query is good to match dial range XXXX.
This runs fine from command prompt as well as CLI but I don’t see any user imported in CUCM while when I used expression ))(|(telephonenumber=2))) it worked cannot match my entire dial range.
DTD generated by XMLSPY v5 rel. 4 U (http://www.xmlspy.com)>
Thannks
Aaron Harrison Fri, 06/18/2010 - 03:00
You can't insert regular expressions to LDAP filters...
The best way to deal with this would be one of these:
1) Ensure that the information in the directory is correct - if the 'longer than 5-digit' extensions aren't correct, correct them. Make them numbers that are diallable properly, there's no point them being in the LDAP directory if they aren't correct.
2) Use an alternate field (i.e. ipPhone) and populate that with the 'checked' extensions. Your LDAP people should be able to put together a script very easily that simply reads each telephoneNumber, and if correct inserts to ipPhone. You then import that.
Aaron
satish rawat Fri, 06/18/2010 - 06:44
Hi Aaron,
I am sorry but I didn’t understand your last post correctly. Here is something that we can do.
How do I create a query to search users whose phone numbers starts with 20000 and ends with 79999. I guess if I can create this and implement this will solve my issue.
Last night I executes another query ( using regular expressions) it didn’t error when executing but it isn’t working.
Please see if you have any idea how to create a query for numbers starting with 20000 and ending with 79999
Satish
Aaron Harrison Fri, 06/18/2010 - 06:55
You can insert ANYTHING into the ldapfilter table; it will accept it and will not validate it. All that will happen is that your LDAP syn won't work, as the filter returns no results. You should test the filter first against your LDAP server - if it's AD, then in AD Users & Computers do a 'custom' search and paste in the filter text.
What I'm saying is that I don't think it's possible to match a range of numbers - you can match the first characters (e.g. telephonenumber=8*) but you can't match based on digit length or number range.
I think you need to investigate why the telephonenumbers in the LDAP directory are not consistent to start with.
Aaron
Related Content
