match protocol http host, Deny URL Cause Slow connection
Apr 27th, 2010
Hello, I'm trying to block Facebook out of customers
I'm using IOS Version 12.4(13r)T  - c3845-adventerprisek9-mz.124-24.T.bin
class-map match-all DENY_FACEBOOK
match access-group name URL_FILTERING
match protocol http host "*facebook*"
policy-map HTTP
class HTTP
  priority percent 75
policy-map URL_FILTERING
class DENY_FACEBOOK
   drop
class class-default
interface GigabitEthernet0/0.250
encapsulation dot1Q 252
ip address 192.168.xxx.xxx 255.255.255.0
ip flow ingress
ip nat inside
ip virtual-reassembly
ip tcp adjust-mss 1452
ip policy route-map HTTPS
no snmp trap link-status
service-policy input URL_FILTERING
ip access-list extended URL_FILTERING
deny   ip host 192.168.x.12 any
deny   ip host 192.168.x.33 any
deny   ip host 192.168.x.56 any
deny   ip host 192.168.x.112 any
permit ip any any
route-map HTTPS permit 10
match ip address HTTPS
set interface Dialer5
I have Adsl ATM hwics,
And Every one that is not Approved(denied) in the ACL URL_FILTERING is experiencing VERY VERY Slow Connection
sometimes it takes like 8 minutes to load google.com until i cancel the block, i have the same configuration on another 3845 with another version
and it works fine, it works only at old versions or something, btw i have to use 2.4(13r)T cause i have hwic adsl cards.
Please let me know if you have answer!
Thanks in advance
stdejongh Wed, 10/13/2010 - 02:12
I'm having exactly the same problem.
My aim is to prevent access to direct-http download sites for people in subnet 172.30.6.0/23.
Router: Cisco IOS Software, 2801 Software (C2801-IPBASE-M), Version 15.1(1)T, RELEASE SOFTWARE (fc1)
interface FastEthernet0/1/0
ip address 172.30.0.1 255.255.255.252
ip nbar protocol-discovery
ip nat inside
ip policy route-map REDIR-SERVERS
duplex auto
speed auto
service-policy input pmap-fa010-in         <-----  THE PROBLEM
service-policy output nc2class-bw-limit  <----- Bandwidth allocation by subnet ... works fine.
policy-map pmap-fa010-in
class CLASS-DIRECTHTTP
   drop
class-map match-all CLASS-DIRECTHTTP
match access-group name CLASSROOMS
match class-map direct-HTTP
class-map match-any direct-HTTP
  match protocol http host "*rapidshare.com*"
ip access-list standard CLASSROOMS
permit 172.30.6.0 0.0.1.255
The result is that the traffic to Rapidshare is really blocked, but other http traffic is very very very slow and sometimes even blocked. It seems that most of the http traffic from the given subnet match the rule ( sh policy-map int fa0/1/0 input => counters increasing when request are sent)
I tested the config on an old 2621XM running AdvIP 12.4(6)T and everything was working fine.
Any help would be welcome.
