04-27-2010 04:38 PM - edited 03-10-2019 05:05 PM
I am in a situtaion where I need to reset the console username/password on one of our ACS 1112 appliances. No one can remember it.
We are in the process of upgrading these devices from version 3.3 to 4.1 (latest version we can run on our only ACS1111 device).
The 3.3 Recovery Disk I have does not boot (probably damaged, or burnt too fast). I have a 4.1 Recovery CD, that I was wondering if I could use instead?
The reason I am asking first before trying is I cant run any risk of corrupting the configuration that is already on there, as it is still in production.
Jeff
Solved! Go to Solution.
04-29-2010 08:52 AM
Jeff,
It has to be the specific version that matches what you are running.
04-28-2010 09:29 AM
The version of the CD used to reset the administrator password has to match the version running on the appliance, or database corruption will occur.
04-28-2010 04:12 PM
Thanks for the reply. This is what I thought.
How accurate doe the version have to be. eg there are 4 numbers, eg 3.3.x.y
Can I use any 3.3 recovery CD, or does it have to be specifically for 3.3.x.y?
Jeff
04-29-2010 08:52 AM
Jeff,
