User logon
damianrodriguez
Hi! i create somes users with level 15 of privilege but i can only access with the admin user using ssh, telnet o http service. When i try using other users i can not access. Thank
2 Accepted Solutions
have you enabled telnet ssh under the vty lines:
line vty 0 4
exec-timeout 60 0
privilege level 15
password damian
login local
length 35
transport input telnet ssh
And try again.
Ganesh Hariharan
Check out the below link on local database configuration for line vty ,ssh etc.
http://www.cisco.com/en/US/products/sw/iosswrel/ps1818/products_configuration_example09186a0080204528.shtml
Hope to Help !!
Ganesh.H
Remember to rate helpful post
8 Replies 8
Damian,
Is this an IOS router, switch?
Do you have the SSH, telnet, HTTP services authenticating against the local database?
Federico.
Is a switch (2960), how can i associate the users with the local database?
Thank
Hi Damian,
If you create a user name without using a any authentication server it will be assassinated with a local database:
example:
username damian privilege 15 password damian123
This will give full privilege to the switch
Reza
OK, but my problem is that the user can not log in using ssh, telnet or http.
Aside from creating the internal user database, you need to check that the SSH, HTTP, telnet, ect authentication is defined
to use local authentication.
For example, for HTTP you need:
ip http authentication local
For SSH and telnet you have to reference the lines vty to local authentication as well.
Federico.
line vty 0 4
exec-timeout 60 0
privilege level 15
password damian
login local
length 35
And try again.
Ganesh Hariharan
Hope to Help !!
Ganesh.H
I try but the command "login local" does not exist.
I have
Ports  Model              SW Version              SW Image
WS-C2960-24TC-L    12.2(35)SE5             C2960-LANBASEK9-M
I can not add a user with the same priv than admin.
