What is the power draw of the SPA500?
Steven Howes Wed, 04/28/2010 - 01:57
It varies a bit depending on what it is doing, but on PoE a 504 generally stays below 5W. Mains could be more/less depending on voltage conversion etc.
S
lzuniga99 Wed, 05/05/2010 - 15:27
Hi Glenn the table you posted it's very help full, that info should be included in the product datasheet.
So I want to confirm, that provided  I have an ESW-520-24P switch with 180 Watts power budget, this switch is supposed to support 24 SPA502 IP Phones at full load?
Thanks.
Glenn Quesenberry Fri, 05/07/2010 - 12:28
  • Cisco Employee,
Per the chart the maximum power draw for the SPA502 is 1.620 watts.  The 180 watt power budget of the ESW-520-24P should be more than sufficient for that number of phones.
Best Regards,
