Ospf logs and snmp Server.
Apr 28th, 2010
I have 3750E with c3750e-universalk9-mz.122-50.SE3 IOS. I have two redundant Links to different ISPs with equal Cost. G0/1 and G0/2, both are advertised in ospf within same area with equal cost. I have snmp enable traps and my snmp is connected in a remote location via these ospf links.
Normally snmp-serve receives these traps via G0/2 link and when G0/2 link fails the snmp-server will receive these traps via g0/1. But in this case snmp-server does not receive the Adj-changes logs OR G0/2 down logs. Logs are generated on local Switch but they are not seen on SNMP-SERVER, so in this case Person Monitoring the snmp-server cannot identify that the link g0/2 is now down or ospf nei is down via g0/2.
help me to resolve this issue.
interface Loopback10
ip address 4.4.4.4 255.255.255.255
interface GigabitEthernet0/1
description =================) normal Snmp tarps are sent from this link after Ge 0/2 goes down = Secondary
no switchport
ip address 10.10.10.1 255.255.255.248
ip ospf network point-to-point
ip ospf cost 10
interface GigabitEthernet0/2
description =================) normal Snmp tarps are sent from this link = primary.
no switchport
ip address 20.20.20.3 255.255.255.248
ip ospf cost 10
router ospf 3
router-id 4.4.4.4
log-adjacency-changes
network 4.4.4.4 0.0.0.0 area 0
network 10.10.10.3 0.0.0.7 area 0
network 20.20.20.3 0.0.0.7 area 0
snmp-server enable traps ospf state-change
snmp-server enable traps ospf errors
snmp-server enable traps ospf retransmit
snmp-server enable traps ospf lsa
snmp-server enable traps ospf cisco-specific state-change nssa-trans-change
snmp-server enable traps ospf cisco-specific state-change shamlink interface-old
snmp-server enable traps ospf cisco-specific state-change shamlink neighbor
snmp-server enable traps ospf cisco-specific errors
snmp-server enable traps ospf cisco-specific retransmit
snmp-server enable traps ospf cisco-specific lsa
Above config is already deployed on the switch.
Can Anyone help me here.
