HSRP API active virtual address x.x.x.x not found
MARVIN SPITERI
I have the below two switches running HSRP on all vlans - sample of one of the vlans - others are configured in the same manner.
On the live network using Stack of 3750 switches, I turned on the 'debug standby events'  and I am getting the below messages of:-
003204: 35w5d: HSRP: Vl40 API active virtual address 10.10.40.56 not found
003205: 35w5d: HSRP: Vl70 API active virtual address 10.10.71.254 found
003206: 35w5d: HSRP: Vl40 API active virtual address 10.10.41.220 not found
003207: 35w5d: HSRP: Vl10 API active virtual address 10.10.10.10 found
003208: 35w5d: HSRP: Vl40 API active virtual address 10.10.41.247 not found
003209: 35w5d: HSRP: Vl50 API active virtual address 10.10.55.254 found
003210: 35w5d: HSRP: Vl40 API active virtual address 10.10.41.242 not found
003211: 35w5d: HSRP: Vl40 API active virtual address 10.10.40.56 not found
003212: 35w5d: HSRP: Vl50 API active virtual address 10.10.55.254 found
003213: 35w5d: HSRP: Vl30 API active virtual address 10.10.30.212 not found
003214: 35w5d: HSRP: Vl40 API active virtual address 10.10.41.216 not found
003215: 35w5d: HSRP: Vl10 API active virtual address 10.10.10.10 found
003216: 35w5d: HSRP: Vl40 API active virtual address 10.10.41.254 found
003217: 35w5d: HSRP: Vl40 API active virtual address 10.10.40.16 not found
003218: 35w5d: HSRP: Vl50 API active virtual address 10.10.55.254 found
further output ommitted...
extract of config
switch 1 - active
interface Vlan40
ip address 10.10.41.252 255.255.254.0
ip helper-address 10.10.10.8
ip helper-address 10.10.10.54
no ip redirects
no ip unreachables
no ip proxy-arp
standby 40 ip 10.10.41.254
standby 40 priority 255
standby 40 preempt
switch 2 - standby
interface Vlan40
ip address 10.10.41.253 255.255.254.0
no ip redirects
no ip unreachables
no ip proxy-arp
standby 40 priority 254
when I tried to replicate it in lab with 4506 and 4510 switches - the debug standby events does not generate any issues...
can someone pls help me understand what those messages are?
jorge.calvo
That is an informational message only. In old IOS versions prior to 12.2, HSRP was a process belonging to IP Routing process. Beginning on 12.2 it is now a separate process. When it is needed, IP Routing queries HSRP process to check if the VIP is already in use by HSRP.
The message you receive is generated when IP Routing queries HSRP to check if the VIP is being used by it but it is not being used at the moment.
So, this is a normal situation that should not affect the network functionality.
Regards.
jorge.calvo
Regards.
many thanks for your reply, yes in fact TAC confirmed that too
