Mmmm
CUCM1 -- CUCM2 -- GW
To which CUCM GW is registered?
The scenario and facts are not normal honestly dont have a logic explanation as one change may not be relate dto the other but fix the issue
"The inbound calling search space on the PRI is set up to only look in one partition that only has translation patterns in it to translate the incoming DID numbers into the extensions. The telco is sending in 4 digits inbound."
What extacly they change in the Translation pattern?
Can you give us an specific example for the CSS configured in GW
The change made of the TP
Which partition the TP is located
Which CSS the TP contains
Exact version of CUCM
To which CUCM the GW is registered
If you can give us CUCM SDI/SDL traces for all nodes including calling/called number and timestamps I can take a look and help you to decipher this one
