SPA2102 Multi-CHannel configuration question
Apr 28th, 2010
I was hoping that someone would know the answer
to this question.  Is it possible to set up a SPA2102 with one did on port 1, and have
have an additional channel on port 2 that calls can roll to if port 1 is busy?  I have some clients that are
small office home office and only need 2 lines, this is the most inexpensive way to accomplish this.
I appreciate any and all help!
Jim
ivelinivanov92 Thu, 04/29/2010 - 00:47
Jim,
Of course it should be possible but the implementation may depend on your particular setup. You can use call_forward_on_busy feature either within the spa or the softswitch if it is under your control.
Hope this helps.
Greetings
