WebVPN blank page after login
Apr 28th, 2010
Hey All,
I am seeing some intermittant issues when trying to login to a WebVPN. I get the login screen, enter my credentials and then click submit I get a blank page. I have disbled webvpn on the outside and re-enabled it. Anyone else see this kind of issue? This was working just fine for the last 4 months. Nothing has changed on the configuration. I have daily backups and have check for differentials and see no differeneces.
Thanks in advance for your help.
bmath Thu, 04/29/2010 - 06:41
What is the Version you running ,Model and how much Ram? and how many simu
ltanius connections you have and chk the mem use.
inetu Mon, 05/03/2010 - 06:48
Hi bmath,
Thanks for the reply. I was running version 8.2(1). I ended up upgrading to 8.2(2) and rebooted the firewall. This corrected the issue with the blank page. I think the reboot ultimately fixed the issue since it was working intermitantly. I figured I  would upgrade since a reboot felt in order. Thanks.
Related Content
