We are interested in configuring our IP Security camera and Video Ops Manager server to support two feeds.
The first feed we want to use is a high quality MJEP feed. This feed will normally not be available to users but will be available to local admins in the case of an event.
The second feed we want to publish is a low-quality feed for use by the user over Citrix. We've been trying to use MPEG-4 128 bitrate but have encountered a few issues.
First, do we need to create both of these feeds on the camera first? If we modify the feed in the Ops Manager Server it seems to change camera feed configuration (it's a 2500). However, if we configure a second feed the camera does not receive the config.
If we configure the feeds manually on the camera they do not work on the Ops Manager.
Secondly, is there any reason why the max resolution on the camera config for the MJPEG is 352x240?
And finally, we've experimented with a child feed but decided against because if we want to use MPEG-4 we are not able to scale back the bandwidth requirement.
