PPPoE and Natting on TCP Ports
Apr 28th, 2010
Dears;
i configured Cisco 2911 router with DSL link and it is working properly but the natting for some services that i want to do to publish it to the internet was not working  and there is no firewalls in my side as follow:
  • i want users from the internet to access my server 172.18.11.3 on port 3391 in inside network.
  • i want users from the internet to access my server 172.18.11.8 on port 3393 in inside network.
  • i want users from the internet to access my server 172.18.11.9 on port 3390 in inside network.
i got the public IP address dynamically from the ISP but the IP is assigned to us permenantly. the public IP is 212.70.55.55 on the Dialer 1 interface. the configuration is below:
HQ-R1#sh ip int brief
Interface                  IP-Address      OK? Method Status                Prot
ocol
GigabitEthernet0/0         172.18.11.101   YES NVRAM  up                    up
GigabitEthernet0/1         unassigned      YES NVRAM  up                    up
GigabitEthernet0/2         unassigned      YES NVRAM  administratively down down
NVI0                             172.18.11.101   YES unset  up                    up
Virtual-Access1             unassigned      YES unset  up                    up
Virtual-Access2             unassigned      YES unset  up                    up
Dialer1                          212.70.55.55    YES IPCP   up                    up
vpdn enable
!interface GigabitEthernet0/0
description Connected to LAN
ip address 172.18.11.101 255.255.255.0
ip nat inside
ip virtual-reassembly
duplex auto
speed auto
interface GigabitEthernet0/1
description connected to the modem (ISP)
no ip address
duplex auto
speed auto
pppoe enable group global
pppoe-client dial-pool-number 1
interface GigabitEthernet0/2
no ip address
shutdown
duplex auto
speed auto
interface Dialer1
ip address negotiated
ip mtu 1492
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication pap callin
ppp chap refuse
ppp ms-chap refuse
ppp pap sent-username xxxx password yyyy
no cdp enable
ip forward-protocol nd
no ip http server
no ip http secure-server
ip nat inside source list 1 interface Dialer1 overload
ip nat inside source static tcp 172.18.11.3 3391 interface Dialer1 3391
ip nat inside source static tcp 172.18.11.8 3393 interface Dialer1 3393
ip nat inside source static tcp 172.18.11.9 3390 interface Dialer1 3390
ip route 0.0.0.0 0.0.0.0 Dialer1
access-list 1 permit any
dialer-list 1 protocol ip permit
please i need your assistance in the natting configuration, and also i tried the access lists with natting ans it didnt work.
Shadi
Federico Coto F... Wed, 04/28/2010 - 15:37
  • Green, 3000 points or more
Shadi,
Do you get the same results if instead of having the NAT like this:
You use the IP?
ip nat inside source static tcp 172.18.11.3 3391 212.70.55.55 3391
ip nat inside source static tcp 172.18.11.8 3393 212.70.55.55 3393
ip nat inside source static tcp 172.18.11.9 3390 212.70.55.55 3390
Anyway, the IP is not going to change right?
Give it a try just to check.
Federico.
eng.shadi Thu, 04/29/2010 - 00:27
Hi Federico;
i tried but it didnt work.
thanks;
Shadi
phausner Thu, 04/29/2010 - 01:15
  • Cisco Employee,
Hi Sahdi,
I have a simllar config running on 2851 and it works perfect. I cna not see any difference to your config. HAve you checked the server? Maybe the default getway is an issue and packetes are not sent back. Maybe also usefull to do a debug on nat translations. Also a point to check is if the server is Windows machine if the windows firewall has been activated and pohibits the service.
PHilipp
eng.shadi Thu, 04/29/2010 - 11:37
Dears;
thanks for your efforts, the issue is solved, as always the admin gave me wrong ports and the gateway was wrong in the servers.
thanks;
Shadi
