Route-map and
Apr 28th, 2010
Hi All,
I have one hub router X on which my 2 mpls links are terminated. Let say ISP A and ISP 2.
I am running OSPF with ISP A and static routing with ISP B.
at remote location I have single router and both MPLS are connected to same router. NOw I have made
ISP B primary with static routes but from that subnet defined in static route I have given a static route toward ISP A for one host with 32 bit mask. Now that single pc is going through ISP A. but from hub side I have one static route toward ISP B for location lan. I am tracking that with sla so if that static route will fail ospf route will be used.
The PC for which static route was defined though ISP A I want traffic from that PC to come back via ISP A for that I have made access list matching that system as source and remote location lan ip address. I have applied a route map if that access list matches I set next hop Ip to ISP A at remote location.THis is working fine.
Now if that ISP A link goes down at location it starts using ISP B for that PC and when traffic goes back from HUB router it matches the route-map and packet gets drop.
Is there any way to configure at HUB that if the location link to ISP A goes down it will start the using ISP B.
ALso what is the use of set ip next-hop verify reachability I applied that also but it is not using the next hop defined in the route-map though the next hop is reachable
Hemant
sharma16031981 Thu, 04/29/2010 - 12:57
That is right I am tracking remote location IP address and added verification though the next hop is up but it still sends data via other static route defined in HUB router. Also if I remove that verification it starts using the route-map and next hop get changed. if I again added verification it again started using the static route. Next hop defined in route-map is definetely pinging.
Hemant
Laurent Aubert Thu, 04/29/2010 - 13:33
  • Cisco Employee,
Please post a diagram describing your L3 topology (including LAN and WAN ip addressing plan) and the routers configuration.
We will continue from there.
Also did you try to replace your route-map by static routes + tracking object ?
Laurent.
sharma16031981 Sat, 05/01/2010 - 15:39
HI laurent,
I am not sharing the actual diagram and configs but I am attaching a basic connectivity and description in  notepad.
Hope that will help you to provide some answer.
Hemant
Laurent Aubert Thu, 05/06/2010 - 08:40
  • Cisco Employee,
Your issue is still unclear. Let me try to summarize it:
- HO and remote location are both connected to ISP A and B
- ISP B is the primary path
- There is a proxy located on HO which is used by the remote location
- Traffic between the proxy and the remote location must go though ISP A as primary and ISP B as backup.
Issue is when ISP A link on HO failed, traffic is well re-routed on ISP B but stay on ISP B once ISP A is UP again.
Is my understanding correct ?
Laurent.
sharma16031981 Sat, 05/08/2010 - 13:43
Hi Laurent,
you are correct with your understanding , so if you could please help in this
Hemant
Laurent Aubert Mon, 05/10/2010 - 06:54
  • Cisco Employee,
Hi Hemant,
In order to help you efficiently, I need the router configuration associated to a detailed topology and the outputs describing the issue.
Laurent.
