Configured a remote spanning session, but the spanning vlan is disabled. How can I enable it?
Apr 28th, 2010
I have trouble spanning traffic in my 6509
Here's my monitor configuration:
Session 2
Type                   : Remote Source Session
Source Ports       :
    Both               : Gi1/1
Destination RSPAN VLAN : 83
and I assigned a trunk port at Gi2/1 allowing vlan 83 to another switch.Gi1/1 is up and has traffic going through. However, there's no traffic through Gi2/1 (up as well) at all.
It looks good. However, when I do show vlan id 83, the remote span vlan is shown disabled:
show vlan id 83
VLAN Name                             Status    Ports
83  RSPAN_VLAN03                     active    Gi2/1, Po1
VLAN Type  SAID       MTU   Parent RingNo BridgeNo Stp  BrdgMode Trans1 Trans2
83  enet  100083     1500  -      -      -        -    -        0      0
Remote SPAN VLAN
Disabled
Primary Secondary Type              Ports
How come the remote span vlan is disabled? and how can I enable it?
Ganesh Hariharan Wed, 04/28/2010 - 23:22
  • Purple, 4500 points or more
  • Community Spotlight Award,
    Member's Choice, February 2016
Session 2
Source Ports       :
    Both               : Gi1/1
show vlan id 83
Remote SPAN VLAN
Disabled
To configure an RSPAN source session, use the same session number for a source and a destination RSPAN VLAN and to configure an RSPAN destination session, use the same session number for a source RSPAN VLAN and a destination port.
Check out the below link for configuring RSPAN in 6500 series switches
http://www.cisco.com/en/US/docs/switches/lan/catalyst6500/ios/12.1E/native/configuration/guide/span.html#wp1043258
Hope to Help !!
Ganesh.H
kahouwong Wed, 04/28/2010 - 23:30
remote spanning was configured correctly as follows
monitor session 1 source vlan 83
monitor session 1 destination interface Gi2/1
but no traffic was mirrored to the destination port
Ganesh Hariharan Thu, 04/29/2010 - 00:15
Can you share the spanning configuration which you have configured in your switch.
Ganesh.H
jpijnaker Fri, 03/13/2015 - 07:35
You need to add the "remote-span" keyword with the vlan configuration of vlan 83.
Related Content
