HSRP MIB entries are still present after suppression of HSRP group.
Apr 29th, 2010
Can someone advice me on a HSRP status from a supervision station :
If we delete a HSRP configuration on a device, the related enties are not accordingly suppressed in the MIB. The consequence is the presence of alarms on the supervision station although we poll the device or either a new device discovery in the supervision station database.
Does some command exists in order to clear these status entries (rebooting the device does clear the entries but reboto not acceptable) ?
Example :
Unconfiguration of HSRP 38.1 index, then :
sxanhm03:/root #grep cisco.ciscoMgmt.ciscoHsrpMIB.ciscoHsrpMIBObjects.cHsrpGroup.cHsrpGrpTable.cHsrpGrpEntry /tmp/cisco.mib | grep 38.1
cisco.ciscoMgmt.ciscoHsrpMIB.ciscoHsrpMIBObjects.cHsrpGroup.cHsrpGrpTable.cHsrpGrpEntry.cHsrpGrpPriority.38.1 : Unsigned32: 100
cisco.ciscoMgmt.ciscoHsrpMIB.ciscoHsrpMIBObjects.cHsrpGroup.cHsrpGrpTable.cHsrpGrpEntry.cHsrpGrpPreempt.38.1 : INTEGER: false
cisco.ciscoMgmt.ciscoHsrpMIB.ciscoHsrpMIBObjects.cHsrpGroup.cHsrpGrpTable.cHsrpGrpEntry.cHsrpGrpActiveRouter.38.1 : IpAddress:x.x.x.x
etc ....
My customer specifies me it seems to be also the case with vrf configuration where MIB entries are still there after suppression . More generally, the behaviour is noticed when dynamic entries are created in the MIB, then suppressed there are still present.
Could it be a bug ?Has someone ever meet this issue ?
Issue noticed on Cisco6506 / s72033-advipservicesk9_wan-mz.122-18.SXF5.bin
Thanks a lot for your feedbacks or advices on it.
Overall Rating: 5 (1 ratings)
smitesh kharecha Fri, 04/30/2010 - 23:03
Hi Karim,
Generally after deleting any config, pollers still generate the alarms as previosly reported trap differs from the current one.
You need to re-scan the device in your pollers so that it becomes aware that config on router is changed.
krahmani323 Tue, 05/04/2010 - 11:45
Hello Smitesh,
Thanks a lot for your answer, but as specified although we poll again the device or either we perform a new device discovery in the  supervision station database, the alarms are still present.
I have opened a TAC Case for that.
Anyway thanks for your answer.
