ASA5505 error writing to flash file system
Answered Question
Apr 29th, 2010
Any idea how to work around this error/problem?
ciscoASA5505# reload
System config has been modified. Save? [Y]es/[N]o:Y
%Error opening disk0:/.private/startup-config (Read-only file system)
Error executing command
Proceed with reload? [confirm]
ciscoASA5505#
I'm remote so formating the flash etc is not a good solution.
Thx,
Phil
Correct Answer by Jennifer Halim about 6 years 8 months ago
When you perform the reformat, it will repair the faulty file system. If that can't be repaired, you would need to replace the flash.
Overall Rating: 5 (1 ratings)
Jennifer Halim Thu, 04/29/2010 - 05:36
Unfortunately you only have 2 options in this situation:
1) Reformat the flash
OR/
2) Reload the ASA
Unfortunately none of them is a good solution when you are remote to the ASA.
Phil Williamson Thu, 04/29/2010 - 05:41
I was afraid that was my only option.
Actually the unit has been reloaded since the error first appeared, but it persists.
Is is possible to format flash, tftp new IOS/ASDM and startup-config and reload with some assurance that I don't end up with an 'electronic brick'?
Correct Answer
Jennifer Halim Thu, 04/29/2010 - 05:50
avdalen1974 Tue, 02/11/2014 - 04:54
When you have issues with your flash, check your flash with fsck.
asafw# fsck disk0:
dosfsck 2.11, 12 Mar 2005, FAT32, LFN
/csco_config/97/bookmarks/Template
  Contains a free cluster (5131). Assuming EOF.
  File size is 881 bytes, cluster chain length is 0 bytes.
  Truncating file to 0 bytes.
Reclaimed 4 unused clusters (32768 bytes) in 2 chains.
Performing changes.
/dev/hda1: 57 files, 12873/31180 clusters
fsck of disk0: complete
Related Content
