concurrent connections most used
k.abillama
Is there a command to display the most used concurrent connections from a WAE since its first operation? In other terms  the Most used conenctions , just like the output of show conn on PIX/ASA
I know the command which  displays the current concurrent connections on a WAE but don't need it, i need the most used
Zach Seils
Level 7
Level 7
What version of WAAS are you running?  In the latest version, the command show stat tfo conn has a "cumulative" connection counter.
Zach
I'm using version 4.1.5 so it should be fine right?
Yes.  The very first line of the output has the counter you are looking for.
Zach
