Standby ACE not switching to active even when priority of active member is decreased due to vlan interface tracking.
Apr 29th, 2010
I have 2 ace in active standby setup with FT configured, FT is working fine when i shut down the active box,at that time my standby becomes active.
I have enabled vlan interface tracking recently, when i shut down the interface from switch to which ACE is connected, i can see the priority is decreased in active ace than stanby but still stanby doenot become active at that time.
FT config:
ft interface vlan 2
  ip address 10.10.10.1 255.255.255.0
  peer ip address 10.10.10.2 255.255.255.0
  no shutdown
ft peer 1
  heartbeat interval 100
  heartbeat count 10
  ft-interface vlan 2
  query-interface vlan 421
ft group 1
  peer 1
  priority 150
  peer priority 145
  associate-context Admin
  inservice
ft track interface AAA
  track-interface vlan 421
  peer track-interface vlan 421
priority 50
  peer priority 5
ft track interface BBB
  track-interface vlan 431
  peer track-interface vlan 431
priority 50
  peer priority 5
Marko Leopold Thu, 04/29/2010 - 23:42
Did you enable the "svclc autostate" command on your switch? It is required for vlan-tracking.
greetings.
Manjunatha Jayaram Fri, 04/30/2010 - 04:28
The fact is the priority of active is getting decreased when i shut the vlan port from switch side.
It is that still i have to enable "svclc autostate" on switch.
Satish Bhat
Gilles Dufour Fri, 04/30/2010 - 02:03
  • Cisco Employee,
Set the priority of the tracked interface to 50.
Gilles.
Manjunatha Jayaram Fri, 04/30/2010 - 04:37
As per my configuration ft track interace AAA & ft track interface BBB , peer track interface should be (ft vlan)vlan 2 or vlan 431 / 421.(interface vlan)
Can some one pls clear my doubt...?
Satish
Marko Leopold Fri, 04/30/2010 - 04:53
I guess it depends on what you want to do. But usually you track on both sides the same vlan, if you want to track this interface.
Gilles Dufour Fri, 04/30/2010 - 05:45
  • Cisco Employee,
sorry  had not seen you already had the priority.
What is the status of 'show ft track det' on each ACE when you shut down the interface ?
Gilles.
Manjunatha Jayaram Sat, 05/01/2010 - 04:43
on primary ace:
LoadBalancer-1/Admin# sh ft group 1 detail
FT Group : 1
No. of Contexts : 1
Context Name : Admin
Context Id : 0
Configured Status : in-service
Maintenance mode : MAINT_MODE_OFF
My State : FSM_FT_STATE_ACTIVE
My Config Priority : 150
My Net Priority : 100
My Preempt : Disabled
Peer State : FSM_FT_STATE_STANDBY_COLD
Peer Config Priority : 145
Peer Net Priority : 145
Peer Preempt : Disabled
Peer Id : 1
Last State Change time : Thu Apr 29 03:30:14 2010
Running cfg sync enabled : Enabled
Running cfg sync status : Peer in Cold State. Error on Standby device when applying configuration file replicated from active
Startup cfg sync enabled : Disabled
Startup cfg sync status : Peer in Cold State. Startup configuration sync is disabled
Bulk sync done for ARP: 1
Bulk sync done for LB: 1
Bulk sync done for ICM: 1
Stanby Ace:
`show ft group detail`
FT Group : 1
No. of Contexts : 1
Context Id : 0
My State : FSM_FT_STATE_STANDBY_COLD
My Config Priority : 145
My Net Priority : 145
Peer State : FSM_FT_STATE_ACTIVE
Peer Config Priority : 150
Peer Net Priority : 100
Peer Id : 1
Last State Change time : Thu Apr 29 04:25:26 2010
Running cfg sync status : Error on Standby device when applying configuration file replicated from active
Startup cfg sync status : Startup configuration sync is disabled
Bulk sync done for ARP: 0
Bulk sync done for LB: 0
Bulk sync done for ICM: 0
Gilles Dufour Mon, 05/03/2010 - 06:47
  • Cisco Employee,
The problem is that you disabled "preempt"
This is required for the standby to take over.
Actually, it is possible that preemot was automatically disabled because the 2 devices are not in-synch
Do a " show ft config-error" to detect the problem.
Gilles.
