Site to Site VPN with ASA 5505 and PIX 501
jerryfreeman
I am set up a site-to-site vpn with an ASA 5505 at one end and a PIX 501 at the other.
I followed the section titled Configuring LAN-to-LAN IPsec VPNs from the Command Line Configuration Guide and added these line to the ASA config:
isakmp policy 10 authentication pre-share
isakmp policy 10 encryption 3des
isakmp policy 10 hash sha
isakmp policy 10 group 2
isakmp policy 10 lifetime 43200
isakmp enable outside
crypto ipsec transform-set TRANSFORM_SET esp-3des esp-sha-hmac
access-list l2l_list extended permit ip 10.0.1.0 255.255.255.0 192.168.1.0 255.255.255.0
tunnel-group yyy.yyy.yyy.yyy type ipsec-l2l
tunnel-group yyy.yyy.yyy.yyy ipsec-attributes
pre-shared-key ****
crypto map CRYPTO_MAP 10 match address l2l_list
crypto map CRYPTO_MAP 10 set peer yyy.yyy.yyy.yyy
crypto map CRYPTO_MAP 10 set transform-set TRANSFORM_SET
crypto map CRYPTO_MAP interface outside
For the PIX I followed the example config in Richard Deal's book Cisco PIX Firewalls and added these lines to the PIX config:
access-list l2l_list permit ip 192.168.1.0 255.255.255.0 10.0.1.0 255.255.255.0
nat (inside) 0 access-list l2l_list
access-list IPSEC permit udp host yyy.yyy.yyy.yyy host xxx.xxx.xxx.xxx eq isakmp
access-list IPSEC permit ah host yyy.yyy.yyy.yyy host xxx.xxx.xxx.xxx
access-list IPSEC permit esp host yyy.yyy.yyy.yyy host xxx.xxx.xxx.xxx
access-group IPSEC in interface outside
isakmp key **** address xxx.xxx.xxx.xxx
crypto map GHA_CRYPTO_MAP 10 ipsec-isakmp
crypto map GHA_CRYPTO_MAP 10 set peer xxx.xxx.xxx.xxx
crypto map GHA_CRYPTO_MAP 10 match address l2l_list
crypto map GHA_CRYPTO_MAP 10 set transform-set TRANSFORM_SET
crypto map GHA_CRYPTO_MAP interface outside
I have not been able to establish a connection between the two devices.  I just don't see what I am missing.  Maybe it is not even possible with these two devices.  The ASA has version is 7.2(4) and I believe the PIX is running version 6.3 (I will have to double check later).
Thanks for your help.
26 Replies 26
Sure that you can establish an IPSec tunnel between both devices.
You're missing the NAT0 statement on the ASA (just like you have it on the PIX, referring the ACL)
Then, you can check if the tunnel is trying to establish with the commands:
sh cry isa sa
sh cry ips sa
Federico.
I added this to the ASA
This is the result:
ASA(config)# sh cry is sa
   Active SA: 1
    Rekey SA: 0 (A tunnel will report 1 Active and 1 Rekey SA during rekey)
Total IKE SA: 1
1   IKE Peer: yyy.yyy.yyy.yyy
    Type    : user            Role    : initiator
    Rekey   : no              State   : MM_WAIT_MSG2
ASA(config)# sh cry ips sa
There are no ipsec sas
The tunnel from the PIX is landing on the wrong tunnel-group because it's being recognized on the ASA as a ''user''
connection. Should be a LAN-to-LAN.
Could you post both configs?
Federico.
ASA Version 7.2(4)
hostname ASA
domain-name xxx.com
enable password **** encrypted
passwd **** encrypted
names
interface Vlan1
nameif inside
security-level 100
ip address 10.0.1.1 255.255.255.0
interface Vlan2
nameif outside
security-level 0
ip address xxx.xxx.xxx.xxx 255.255.255.240
interface Vlan3
no forward interface Vlan1
nameif dmz
security-level 50
no ip address
interface Ethernet0/0
switchport access vlan 2
interface Ethernet0/1
interface Ethernet0/2
interface Ethernet0/3
interface Ethernet0/4
interface Ethernet0/5
interface Ethernet0/6
interface Ethernet0/7
banner exec Authorized Access Only!!
ftp mode passive
clock timezone CST -6
clock summer-time CDT recurring
dns server-group DefaultDNS
domain-name xxx.com
object-group protocol TCPUDP
protocol-object udp
protocol-object tcp
access-list outside_in extended permit icmp any any echo-reply
access-list outside_in extended permit icmp any any time-exceeded
access-list outside_in extended permit tcp any interface outside eq pptp
access-list outside_in extended permit tcp any interface outside eq 3389
access-list outside_in extended permit tcp any interface outside eq ftp
access-list outside_in extended permit tcp any interface outside eq www
access-list outside_in extended permit tcp any interface outside eq https
access-list outside_in extended permit tcp any interface outside eq 3101
access-list split_tunnel extended permit ip 172.17.3.0 255.255.255.0 any
access-list split_tunnel extended permit ip 192.168.0.0 255.255.255.0 any
access-list no_nat extended permit ip 192.168.0.0 255.255.255.0 172.16.49.0 255.255.255.0
access-list no_nat extended permit ip 192.168.0.0 255.255.255.0 172.17.3.0 255.255.255.0
pager lines 24
logging asdm informational
mtu inside 1500
mtu outside 1500
mtu dmz 1500
ip local pool dynamic_vpn_pool 172.17.3.1-172.17.3.254 mask 255.255.255.0
icmp unreachable rate-limit 1 burst-size 1
asdm image disk0:/asdm-524.bin
no asdm history enable
arp timeout 14400
global (outside) 1 interface
nat (inside) 1 0.0.0.0 0.0.0.0
static (inside,outside) tcp interface ftp 10.0.1.5 ftp netmask 255.255.255.255
static (inside,outside) tcp interface pptp 10.0.1.10 pptp netmask 255.255.255.255
static (inside,outside) tcp interface smtp 10.0.1.11 smtp netmask 255.255.255.255
static (inside,outside) tcp interface www 10.0.1.11 www netmask 255.255.255.255
static (inside,outside) tcp interface https 10.0.1.11 https netmask 255.255.255.255
static (inside,outside) tcp interface 3389 10.0.1.11 3389 netmask 255.255.255.255
access-group outside_in in interface outside
route outside 0.0.0.0 0.0.0.0 xxx.xxx.xxx.xxx 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat 0:05:00
timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip-disconnect 0:02:00
timeout sip-provisional-media 0:02:00 uauth 0:05:00 absolute
aaa authentication http console LOCAL
aaa authentication telnet console LOCAL
aaa authentication ssh console LOCAL
http server enable
http 192.168.1.0 255.255.255.0 inside
http 10.0.1.0 255.255.255.0 inside
no snmp-server location
no snmp-server contact
snmp-server enable traps snmp authentication linkup linkdown coldstart
crypto isakmp enable outside
crypto isakmp policy 10
encryption 3des
hash sha
group 2
lifetime 43200
telnet 10.0.1.0 255.255.255.0 inside
telnet 172.17.3.0 255.255.255.0 inside
telnet timeout 5
ssh 66.226.222.16 255.255.255.240 outside
ssh timeout 5
console timeout 0
group-policy employees internal
group-policy employees attributes
dns-server value 10.0.1.15
vpn-idle-timeout 720
split-tunnel-policy tunnelspecified
split-tunnel-network-list value split_tunnel
default-domain value xxx.com
username twistadmin password ***** encrypted privilege 15
username administrator password ***** encrypted privilege 15
tunnel-group employees type ipsec-ra
tunnel-group employees general-attributes
address-pool dynamic_vpn_pool
authentication-server-group (outside) LOCAL
default-group-policy employees
tunnel-group employees ipsec-attributes
pre-shared-key *
pre-shared-key ****
class-map inspection_default
match default-inspection-traffic
policy-map global_policy
class inspection_default
  inspect pptp
  inspect ftp
service-policy global_policy global
prompt hostname context
Cryptochecksum:8aab3de376588b71bb7ac1c89f9d07ca
: end
Message was edited by: jerryfreeman
Here is the PIX config.
PIX Version 6.3(1)
interface ethernet0 auto
interface ethernet1 100full
nameif ethernet0 outside security0
nameif ethernet1 inside security100
hostname PIX
domain-name xxx.com
clock summer-time CDT recurring 2 Sun Mar 2:00 1 Sun Nov 2:00
fixup protocol ftp 21
fixup protocol h323 h225 1720
fixup protocol h323 ras 1718-1719
fixup protocol http 80
fixup protocol ils 389
fixup protocol rsh 514
fixup protocol rtsp 554
fixup protocol sip 5060
fixup protocol sip udp 5060
fixup protocol skinny 2000
fixup protocol smtp 25
fixup protocol sqlnet 1521
names
pager lines 24
mtu outside 1500
mtu inside 1500
ip address outside dhcp setroute
ip address inside 192.168.1.1 255.255.255.0
ip audit info action alarm
ip audit attack action alarm
pdm logging informational 100
pdm history enable
arp timeout 14400
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
timeout xlate 0:05:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 rpc 0:10:00 h225 1:00:00
timeout h323 0:05:00 mgcp 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
aaa-server TACACS+ protocol tacacs+
aaa-server RADIUS protocol radius
aaa-server LOCAL protocol local
http server enable
snmp-server community public
no snmp-server enable traps
floodguard enable
crypto map CRYPTO_MAP 10 ipsec-isakmp
crypto map CRYPTO_MAP 10 set peer xxx.xxx.xxx.xxx
isakmp key ******** address xxx.xxx.xxx.xxx netmask 255.255.255.255
isakmp identity address
isakmp policy 10 lifetime 7200
telnet 192.168.1.0 255.255.255.0 inside
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd address 192.168.1.100-192.168.1.120 inside
dhcpd dns 8.8.8.8 8.8.4.4
dhcpd lease 3600
dhcpd ping_timeout 750
dhcpd auto_config outside
dhcpd enable inside
terminal width 80
Cryptochecksum:8f870843699a2bc0307a73eb8eafd4f2
: end
On both sides, phase 1 is the same.
So, please make sure that the peer IPs are matching as well.
On the ASA:
pre-shared-key ****
The IP defined above should be the public IP where the tunnel is going to terminate (outside IP of the PIX)
The pre-shared-key should match the pre-shared key on the PIX.
On the PIX:
Check that the IP and key defined also match the outside IP of the ASA.
If everything above is correct, also verify the peer statement under the crypto maps, that the're pointing to the correct IPs.
Federico.
I've verified the IP addresses and keys on both devices and I'm still not able to get them to link up.  I really have no idea why this is not working.
Could you please post the debugs from the ASA when trying to establish the tunnel?
debug cry isa 127
debug cry ips 127
Federico.
Thanks for your patience with me, Federico.
ASA(config)# debug cry isa 127
ASA(config)# Apr 29 13:57:45 [IKEv1 DEBUG]: Pitcher: received a key acquiremessage, spi 0x0
Apr 29 13:57:45 [IKEv1]: IP = 76.183.133.235, IKE Initiator: New Phase 1, Intf inside, IKE Peer 76.183.133.235  local Proxy Address 10.0.1.0, remote Proxy Addre
ss 192.168.1.0,  Crypto map (CRYPTO_MAP)
Apr 29 13:57:45 [IKEv1 DEBUG]: IP = OutsidePIXAddress, constructing ISAKMP SA paylo
ad
Apr 29 13:57:45 [IKEv1 DEBUG]: IP = OutsidePIXAddress, constructing Fragmentation V
ID + extended capabilities payload
Apr 29 13:57:45 [IKEv1]: IP = OutsidePIXAddress, IKE_DECODE SENDING Message (msgid=
0) with payloads : HDR + SA (1) + VENDOR (13) + NONE (0) total length : 108
Apr 29 13:57:50 [IKEv1 DEBUG]: Pitcher: received a key acquire message, spi 0x0
Apr 29 13:57:50 [IKEv1]: IP = OutsidePIXAddress, Queuing KEY-ACQUIRE messages to be
processed when P1 SA is complete.
Apr 29 13:57:53 [IKEv1]: IP = OutsidePIXAddress, IKE_DECODE RESENDING Message (msgi
d=0) with payloads : HDR + SA (1) + VENDOR (13) + NONE (0) total length : 108
Apr 29 13:57:56 [IKEv1 DEBUG]: Pitcher: received a key acquire message, spi 0x0
Apr 29 13:57:56 [IKEv1]: IP = OutsidePIXAddress, Queuing KEY-ACQUIRE messages to be
Apr 29 13:58:01 [IKEv1]: IP = OutsidePIXAddress, IKE_DECODE RESENDING Message (msgi
Apr 29 13:58:01 [IKEv1 DEBUG]: Pitcher: received a key acquire message, spi 0x0
Apr 29 13:58:01 [IKEv1]: IP = OutsidePIXAddress, Queuing KEY-ACQUIRE messages to be
Apr 29 13:58:09 [IKEv1]: IP = 76.183.133.235, IKE_DECODE RESENDING Message (msgi
Apr 29 13:58:17 [IKEv1 DEBUG]: IP = OutsidePIXAddress, IKE MM Initiator FSM error h
istory (struct &0x42ee820)  , :  MM_DONE, EV_ERROR-->MM_WAIT_MSG2,
EV_RETRY-->MM_WAIT_MSG2, EV_TIMEOUT-->MM_WAIT_MSG2, NullEvent-->MM_SND_MSG1, EV
_SND_MSG-->MM_SND_MSG1, EV_START_TMR-->MM_SND_MSG1, EV_RESEND_MSG-->MM_WAIT_MSG2
, EV_RETRY
Apr 29 13:58:17 [IKEv1 DEBUG]: IP = OutsidePIXAddress, IKE SA MM:87862c4c terminati
ng:  flags 0x01000022, refcnt 0, tuncnt 0
Apr 29 13:58:17 [IKEv1 DEBUG]: IP = OutsidePIXAddress, sending delete/delete with r
eason message
Apr 29 13:58:17 [IKEv1]: IP = OutsidePIXAddress, Removing peer from peer table fail
ed, no match!
Apr 29 13:58:17 [IKEv1]: IP = OutsidePIXAddress, Error: Unable to remove PeerTblEnt
ry
ASA(config)# debug cry ips 127
ASA(config)# Apr 29 14:01:07 [IKEv1 DEBUG]: Pitcher: received a key acquire
message, spi 0x0
Apr 29 14:01:07 [IKEv1]: IP = OutsidePIXAddress, IKE Initiator: New Phase 1, Intf i
nside, IKE Peer OutsidePIXAddress local Proxy Address 10.0.1.0, remote Proxy Addre
Apr 29 14:01:07 [IKEv1 DEBUG]: IP = OutsidePIXAddress, constructing ISAKMP SA paylo
ad
Apr 29 14:01:07 [IKEv1 DEBUG]: IP = OutsidePIXAddress, constructing Fragmentation V
Apr 29 14:01:07 [IKEv1]: IP = OutsidePIXAddress, IKE_DECODE SENDING Message (msgid=
Apr 29 14:01:12 [IKEv1 DEBUG]: Pitcher: received a key acquire message, spi 0x0
Apr 29 14:01:12 [IKEv1]: IP = OutsidePIXAddress, Queuing KEY-ACQUIRE messages to be
Apr 29 14:01:15 [IKEv1]: IP = 76.183.133.235, IKE_DECODE RESENDING Message (msgi
Apr 29 14:01:18 [IKEv1 DEBUG]: Pitcher: received a key acquire message, spi 0x0
Apr 29 14:01:18 [IKEv1]: IP = 76.183.133.235, Queuing KEY-ACQUIRE messages to be
Apr 29 14:01:23 [IKEv1]: IP = OutsidePIXAddress, IKE_DECODE RESENDING Message (msgi
Apr 29 14:01:23 [IKEv1 DEBUG]: Pitcher: received a key acquire message, spi 0x0
Apr 29 14:01:23 [IKEv1]: IP = 76.183.133.235, Queuing KEY-ACQUIRE messages to be
Apr 29 14:01:31 [IKEv1]: IP = 76.183.133.235, IKE_DECODE RESENDING Message (msgi
Apr 29 14:01:36 [IKEv1 DEBUG]: Pitcher: received a key acquire message, spi 0x0
Apr 29 14:01:36 [IKEv1]: IP = OutsidePIXAddress, Queuing KEY-ACQUIRE messages to be
Apr 29 14:01:38 [IKEv1 DEBUG]: Pitcher: received a key acquire message, spi 0x0
Apr 29 14:01:38 [IKEv1]: IP = OutsidePIXAddress, Queuing KEY-ACQUIRE messages to be
Apr 29 14:01:39 [IKEv1 DEBUG]: Pitcher: received a key acquire message, spi 0x0
Apr 29 14:01:39 [IKEv1]: IP = OutsidePIXAddress, Queuing KEY-ACQUIRE messages to be
Apr 29 14:01:39 [IKEv1 DEBUG]: IP = OutsidePIXAddress, IKE MM Initiator FSM error h
istory (struct &0x4123368)  , :  MM_DONE, EV_ERROR-->MM_WAIT_MSG2,
, EV_RETRY
Apr 29 14:01:39 [IKEv1 DEBUG]: IP = OutsidePIXAddress, IKE SA MM:2eaca391 terminati
Apr 29 14:01:39 [IKEv1 DEBUG]: IP = OutsidePIXAddress, sending delete/delete with r
eason message
Apr 29 14:01:39 [IKEv1]: IP = OutsidePIXAddress, Removing peer from peer table fail
ed, no match!
Apr 29 14:01:39 [IKEv1]: IP = OutsidePIXAddress, Error: Unable to remove PeerTblEnt
ry
Apr 29 14:01:41 [IKEv1 DEBUG]: Pitcher: received a key acquire message, spi 0x0
Apr 29 14:01:41 [IKEv1]: IP = OutsidePIXAddress, IKE Initiator: New Phase 1, Intf i
Apr 29 14:01:41 [IKEv1 DEBUG]: IP = OutsidePIXAddress, constructing ISAKMP SA paylo
ad
Apr 29 14:01:41 [IKEv1 DEBUG]: IP = OutsidePIXAddress, constructing Fragmentation V
Apr 29 14:01:41 [IKEv1]: IP = OutsidePIXAddress, IKE_DECODE SENDING Message (msgid=
Apr 29 14:01:44 [IKEv1 DEBUG]: Pitcher: received a key acquire message, spi 0x0
Apr 29 14:01:44 [IKEv1]: IP = OutsidePIXAddress, Queuing KEY-ACQUIRE messages to be
Apr 29 14:01:49 [IKEv1]: IP = OutsidePIXAddress, IKE_DECODE RESENDING Message (msgi
Apr 29 14:01:50 [IKEv1 DEBUG]: Pitcher: received a key acquire message, spi 0x0
Apr 29 14:01:50 [IKEv1]: IP = OutsidePIXAddress, Queuing KEY-ACQUIRE messages to be
ASA(config)# Apr 29 14:01:57 [IKEv1]: IP = OutsidePIXAddress, IKE_DECODE RESEND
ING Message (msgid=0) with payloads : HDR + SA (1) + VENDOR (13) + NONE (0) tota
l length : 108
Apr 29 14:02:05 [IKEv1]: IP = OutsidePIXAddress, IKE_DECODE RESENDING Message (msgi
ASA(config)#
ASA(config)# Apr 29 14:02:13 [IKEv1 DEBUG]: IP = OutsidePIXAddress, IKE MM Init
iator FSM error history (struct &0x41dff08)  , :  MM_DONE, EV_ERRO
R-->MM_WAIT_MSG2, EV_RETRY-->MM_WAIT_MSG2, EV_TIMEOUT-->MM_WAIT_MSG2, NullEvent-
->MM_SND_MSG1, EV_SND_MSG-->MM_SND_MSG1, EV_START_TMR-->MM_SND_MSG1, EV_RESEND_M
SG-->MM_WAIT_MSG2, EV_RETRY
Apr 29 14:02:13 [IKEv1 DEBUG]: IP = OutsidePIXAddress, IKE SA MM:83d9df69 terminati
Apr 29 14:02:13 [IKEv1 DEBUG]: IP = OutsidePIXAddress, sending delete/delete with r
eason message
Apr 29 14:02:13 [IKEv1]: IP = OutsidePIXAddress, Removing peer from peer table fail
ed, no match!
Apr 29 14:02:13 [IKEv1]: IP = OutsidePIXAddress, Error: Unable to remove PeerTblEnt
ry
The only thing that I've noticed is that the outside IP of the PIX is given by DHCP.
Is this IP dynamic or static?
Normally with DHCP, you require a dynamic-to-static IPsec configuration on the ASA (if the outside IP of the PIX changes).
Have you checked that the outside IP of the PIX is the same as the peer's IP on the ASA?
Do you have any other tunnels currently active on either side? sh cry isa sa
Federico.
The outside address of the PIX is dynamic and the address of the ASA is static.
So should I change these lines on the ASA from this
to this?
crypto dynamic-map DYN_MAP 10 match address l2l_list
crypto dynamic-map DYN_MAP 10 set transform-set TRANSFORM_SET
crypto map CRYPTO_MAP 10 ipsec-isakmp dynamic DYN_MAP
crypto map DYN_MAP interface outside
Are there any other changes I need to make to the ASA or the PIX to use the dynamic address of the PIX?
That's what you need correct.
Please try with that configuration.
The ASA side will have a dynamic map and the PIX will still use a static map configuration.
Federico.
Still not having any luck getting this figured out.  Here are the configs for the ASA and PIX.  I am sure I am missing something simple, but I can't find it.
When I try to ping from the 10.0.1.0 network to 192.168.1.0 network, I get no response.
This is the output I get when I use sh cry ip sa on the ASA:
This is the output I get when I use sh cry is sa on the ASA:
There are no isakmp sas
ASA Version 7.2(4)
hostname ASA
domain-name xxx.com
enable password removed encrypted
passwd removed encrypted
names
interface Vlan1
nameif inside
security-level 100
interface Vlan2
nameif outside
security-level 0
interface Vlan3
nameif dmz
security-level 50
no ip address
ftp mode passive
domain-name xxx.com
protocol-object udp
protocol-object tcp
access-list outside_in extended permit tcp 64.18.0.0 255.255.240.0 interface outside eq smtp
pager lines 24
mtu inside 1500
mtu outside 1500
mtu dmz 1500
arp timeout 14400
static (inside,outside) tcp 65.44.73.211 ftp 10.0.1.91 ftp netmask 255.255.255.255
static (inside,outside) tcp interface 5000 10.0.1.39 5000 netmask 255.255.255.255
static (inside,outside) tcp interface 5003 10.0.1.39 5003 netmask 255.255.255.255
static (inside,outside) tcp interface 5200 10.0.1.39 5200 netmask 255.255.255.255
static (inside,outside) tcp interface telnet 10.0.1.40 telnet netmask 255.255.255.255
route outside 0.0.0.0 0.0.0.0 xxx.xxx.xxx.209 1
http server enable
crypto map CRYPTO_MAP 99 ipsec-isakmp dynamic DYN_MAP
encryption 3des
hash sha
group 2
lifetime 86400
telnet timeout 60
ssh timeout 5
console timeout 0
username twistadmin password removed encrypted privilege 15
username administrator password removed encrypted privilege 15
tunnel-group DefaultL2LGroup ipsec-attributes
pre-shared-key *
pre-shared-key *
  inspect pptp
  inspect ftp
Cryptochecksum:6fa6e6b3e629202b55a6cbd06be0df0b
: end
PIX Version 6.3(1)
hostname PIX
domain-name xxx.com
fixup protocol pptp 1723
names
pager lines 24
mtu outside 1500
mtu inside 1500
pdm history enable
arp timeout 14400
http server enable
floodguard enable
isakmp policy 10 lifetime 86400
telnet timeout 5
ssh timeout 5
console timeout 0
dhcpd lease 3600
dhcpd enable inside
terminal width 80
Cryptochecksum:88882f95e4ea5623e1ae6b3a24af1a01
: end
On the ASA, remove these two lines and try again please:
no crypto map CRYPTO_MAP 10 match address l2l_list
no crypto map CRYPTO_MAP 10 set transform-set TRANSFORM_SET
Federico.
