Connecting a PC directly to a PE
Answered Question
Apr 29th, 2010
Is there a way to make a  MPLS VPN with a CE and a PC connected directly to a PE.
Thanks in advance.
Correct Answer by smitesh kharecha about 6 years 11 months ago
What i have understood so far with your scenario is
You have got 2 connection to PE router. From PE router, one is goin to ur CE and another  is going to ur PC.
For PC-PE connectivity. Add static route to your PC and redistribute them in PE.
For CE-PE, i guess that simply and can you any of the CE-PE connectivity options...
Overall Rating: 4 (1 ratings)
royalblues Thu, 04/29/2010 - 08:52
  • Green, 3000 points or more
Yes it is perfectly possible but will be never be a scenario in real life
Another thing would be that the PE will either be redistributing connected routes or must use static if you have more than one network on the PC.
Narayan
drojasug33 Thu, 04/29/2010 - 09:26
Ok, but the configurations I've tried, need mpls in the CE. I thought i would need mpls, and with the pc i cant have that.
Thanks a lot for your help.
Correct Answer
smitesh kharecha Fri, 04/30/2010 - 00:37
  • Silver, 250 points or more
