Is there any log for lost skinny message in Call Manager?
Answered Question
Apr 29th, 2010
Hi All,
We are trying to find whether the skinny message got lost along the path. Is there any log file in call manager we can check for this purose. Shows whether the skinny message has been sent to the ip phone successfully or not.
Thanks a lot!
Lou
Correct Answer by Jaime Valencia about 7 years 1 month ago
Unfortunately there is no such log, you would need to get a sniffer capture on both ends during some test calls to determine if you don't receive all the SCCP messages in the other end
java
If this helps, please rate
www.cisco.com/go/pdihelpdesk
Overall Rating: 5 (1 ratings)
Correct Answer
Jaime Valencia Thu, 04/29/2010 - 10:14
  • Cisco Employee,
  • Hall of Fame,
    2011
java
