2 line phone- ring on one - flash on the other
michaeljbyrne
I have a user that wants the have the first line on their phone to flahs only. - I have that working.
Line 2 should ring - But it's only flashing. I set it on the line to ring. not sure if I am missing anything else.
CUCMBE7.13
Rob Huffman
Hi Michael,
No you haven't missed anything that I can think of
Two things to try;
1. Try setting Line 2 to "use system default" which should be to Ring (make sure to update/reset)
2. Have the user actually unplug the phone, whenever we have a wierd ringer problem this usually works
Cheers!
Rob
dcarhart
Also make sure these lines are not on any other phones and if they are make sure they have the same setting
I have seen it do wierd things like this when you have the same line on mulitple phones
