Callmanager 7 TFTP download
Answered Question
Apr 29th, 2010
I am trying to add ringtones for users to select.
In the directions I've found it says you need to edit the .xml file.
When I am in the OS serviceability window I don't see an option to download the already existing file to edit it.
How do I download this file so I can edit it?
Thank you.
Correct Answer by William Bell about 6 years 12 months ago
From the server console:
admin: file get tftp Ringlist.xml
Follow the prompts and dump the .xml file to a SFTP server.
HTH.
Bill
Overall Rating: 5 (2 ratings)
Correct Answer
William Bell Thu, 04/29/2010 - 14:25
  • Purple, 4500 points or more
HTH.
Bill
Aaron Harrison Fri, 04/30/2010 - 01:47
  • Community Spotlight Award,
    Member's Choice, May 2015
Or the lazy way:
Tftp get RingList.xml
(from a Windows client)
Aaron
